Low-distortion Audio-range Oscillator - Page 48 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 24th September 2012, 10:08 PM   #471
dchisholm's Avatar
Originally Posted by dirkwright View Post
How do I control the gain of this oscillator from Linear Technology? I just ordered the parts. I want to try it out, but I don't need 20V output!
Add a passive attenuator, perhaps followed by a low-corruption buffer. The oscillator output level was probably engineered to be a particular value that balanced overall distortion against noise.
Changing the output level would require adjusting values in the temperature-compensated peak detector circuit (the two diodes that should be mounted in close proximity, the 5V "Zener", and the 10K and 14K 1% resistors). At first glance, the design seems rather straightforward (the two diodes carry equal average current at the designed output level) but I'd like to have that assumption confirmed before modifying the design. Does the associated AppNote mention anything about this piece of the circuit?
Dale
Old 25th September 2012, 12:57 AM   #472
dirkwright's Avatar
Dale
Thank you for looking at this for me. The link to the document is here:
http://cds.linear.com/docs/Application%20Note/an43f.pdf
page 33 has this particular figure.
Figures 43 and 45 show a similar schematic with a different reference, set at 1.2V and the output is 1Vrms, but the arrangement is different from figure 48.
I looked a little at the HP200 series oscillators and they seem to use an output attenuator, but I don't know for sure.
Old 25th September 2012, 03:06 PM   #473
dirkwright's Avatar
Now I feel like an idiot for ordering the parts for the LT oscillator that outputs 20V p-p. I wish I was smarter so I could modify this circuit for something more reasonable like 2Vrms output. I wanted something I could build myself. One thing I don't like about Victor's oscillator is the fact that there's no way to mount it without grounding it. I suppose I could use a piece of plastic but it just seems so cheap to do it that way. I've got a super duper box and I want to put something really professional inside of it. Sometimes I feel like I'm a chicken running around without a head...
Old 25th September 2012, 04:04 PM   #474
dirkwright's Avatar
Can I put an attenuator between the LT1115 and the output buffer LT1010?
Old 25th September 2012, 05:08 PM   #475
dirkwright's Avatar
oops, never mind. that won't work.
Old 25th September 2012, 07:39 PM   #476
davada is offline davada  Canada
The LT1010 is very prone to high frequency oscillation. I had one oscillate near 100 MHz.
They work great if one uses what's outline in the data sheet.
David.
David.
Old 25th September 2012, 08:32 PM   #477
zigzagflux's Avatar
I use a Hammond aluminum enclosure, with surface mount terminal block going through holes in the side of the enclosure. +/-VDC power supply, +/- signal output, and an earth terminal which is bonded to the enclosure. Victor's oscillator is supported inside with standoffs epoxied to the enclosure (JB Weld) and then the PCB is glued to the standoffs in two places where there are no electrical connections to the circuit. That way the oscillator is securely mounted inside a metal enclosure, and the I/O is isolated from ground for a more or less balanced output. Works very well for low cost.
To keep the enclosure small, I did replace the carbon pot with a Bourns multiturn pot. That is also glued to the pcb with the adjustment screw pointing up. I remove the cover if I need to make adjustments (which I don't, it's just set for 2V output).
I can provide pictures if you need a better description. A little effort, but the oscillator operates so well it was hard not to make it work.
Old 25th September 2012, 08:44 PM   #478
dchisholm's Avatar
Without sitting down and actually THINKING about it (Thinking makes my brain hurt!), Fig 48 seems more intuitively straightforward than Fig 43 or Fig 45.
If a lower output level is the main factor (disregarding noise performance), reduce the voltage rating of the LT1029. Something like the LT1034-1.2 should get you in the right range, then you can adjust the values of the 10K and 14K resistors to get the voltage you want. Increase the 10K or reduce the 14K to increase the output voltage; and vice-versa.
Dale
Old 25th September 2012, 09:50 PM   #479
dirkwright's Avatar
Dale
Yes, I am familiar with the brain hurting bit. I read the app note section on Wein bridge oscillators a couple of times and I still don't understand completely how this works.
OK, so I can replace the LT1029 with a lower reference voltage, and then alter the ratio of the 10k and 14k resistors to change the output. Maybe I can do that with a pot?
In my head, I have a nice single board with the variable frequency and output oscillator driving two single ended outputs, and also a pair of mixed feedback drivers for two transformer balanced outputs. This way, a stereo ADC can take one input directly from the oscillator, and the other input can come through the D.U.T. In the computer, I can do a L-R in the FFT and take out the distortion from the oscillator, leaving only the junk from the D.U.T.
Old 26th September 2012, 01:12 AM   #480
dirkwright's Avatar
David.
OK, thanks for the warning.
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright 1999-2017 diyAudio
