Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 12th September 2012, 08:06 PM   #351
richiem is offline richiem  United States
richiem's Avatar
Tune the filter peak to the 1kHz fundamental and let the skirts take care of themselves -- and it does depend on Q. The primary advantage of a bandpass over a lowpass is deeper attenuation at the 2nd H.
Dick Moore
Old 12th September 2012, 08:13 PM   #352
dirkwright's Avatar
What should be the impedance of the filter?
I'm going to need a good sized box to hold all of this stuff!
Old 12th September 2012, 08:20 PM   #353
scott wurcer's Avatar
Originally Posted by Samuel Groner View Post
I'm answering my first Q myself now that I have the preprint in front of me--20 kHz. Would be interested to see the filter schematic (i.e. order and impedance niveau).
2nd order 600 Ohms. Don't remember the values. #16 copper magnet wire and the best film caps we had.
Samuel
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 12th September 2012, 08:47 PM   #354
richiem's Avatar
@dirkwright -- difficult to say -- it majorly depends on the output capabilities of the device doing the driving. In the case of low-distortion oscillators, I would shoot for a high peak Z, but I haven't done a serious LC bandpass filter in years and just don't remember the practical consequences of various issues. There probably are many sites online that can help with basic design parameters and results.
Dick Moore
Old 12th September 2012, 08:51 PM   #355
dirkwright's Avatar
Wouldn't the filter determine the effective source impedance for the oscillator/filter combination? I'm not sure what kind of load Victor's oscillator can drive, so I don't have a clue as to what impedance to make the filter. I do know that this online calculator I'm using gives me huge inductors for 10kohms characteristic impedance.
http://www.the12volt.com/caraudio/crosscalc2.asp#cc
So, assuming the oscillator can't drive very much, I'd need a buffer between it and the filter if the filter was low impedance.
Old 12th September 2012, 09:09 PM   #356
richiem's Avatar
Well, a bandpass filter will have relatively hi Z at the peak, where the signal level is also highest, and lower Z in the stop band. So using some series R at the output of the oscillator will be a good idea -- I suggest a couple of kohms just to keep the load on the oscillator light, even in the stop band. The resulting insertion loss shouldn't be high at the fundamental, which is the one and only frequency you want.
Dick Moore
Old 12th September 2012, 09:14 PM   #357
dirkwright's Avatar
OK, thanks. So, if the filter is 600 ohms, then that would be the source impedance for the oscillator/filter combination, and I can insert a couple of kohms between the oscillator and the filter to keep the oscillator happy. Sounds good. I don't have to make or buy monster inductors!
Old 12th September 2012, 10:59 PM   #358
richiem's Avatar
Well, you do have to worry about the loss between the osc, output and the filter input at the filter's peak frequency. I would design the filter for a higher nominal Z, but as I said, it's been awhile since I did any work with passive LC bandpass filters and I just don't remember the Z characteristics at all. Just see what you can find online as far as designs go. It doesn't take much Q to do a really good job -- I'd shoot for anything over 6 but less than 60....
Dick Moore
Old 13th September 2012, 01:11 AM   #359
dirkwright's Avatar
Plot for 18dB/octave, 600 ohms, terminated with 600ohm resistor. Pretty good I think.
Old 13th September 2012, 01:24 AM   #360
1audio is online now 1audio  United States
That's pretty impressive. What does it spec for parts? And make sure the inductors are real (have realistic DCR). FWIW I use the free version of this Downloads which works really well. Then move the design to LTSpice to tweak.
Demian Martin
Product Design Services
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 19 21st January 2013 05:37 AM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2013 diyAudio
