Low-distortion Audio-range Oscillator - Page 318 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 14th October 2013, 09:40 PM   #3171
davada is offline davada  Canada
Originally Posted by RNMarsh View Post
Forget this route... we aren't professional programmers and the learning curve is too steep. I too have done some machine language coding and some high level language coding but that was a long time ago. Enough to understand what would be involved. It was an interesting thought, though.
I don't mind starting with what has already been done and copying it and along the way do some subs for parts as an update. Similar to remaking B.Cordell's THD meter design with relays instead and other easy or obvious changes.
What can we do with what has already been done and move on to pcb layout. No feature creep, either.
But. But... I really want the analyzer section. When will that be able to be shown?
Thx-RNMarsh
Well lets see. It took ten lines of code to do a proportional controller that uses a numeric accumulator rather than an integrator to drive the error to zero. Four lines of that are for receiving and transmitting the data. Three lines of code for an integer DSP exponential moving average to remove 60Hz hum, 120Hz ripple and other noise. The rest is configuration of the controller and getting the digital electronics to work properly.
David.
Old 14th October 2013, 10:15 PM   #3172
1audio is online now 1audio  United States
i think using a microcontroller to steer the system is a great idea. Everything from autoranging to limited automatic analysis of the post notch information can be done with a $5 micro today. Stuff that takes 4-5 PCB's in the Shibasoku.
It s a perfectly normal evolution. There are more than a few people around here with the skills in spades to hadle the programming. What is necessary is to figure out what they need to program it to do.
For a complete audio analyzer I would suggest the following-
Oscillator frequency
Oscillator level
Analyzer tuning/auto
Analyzer input/autoranging
Level calculations (volts/db)
Level ratios in to out
frequency in
All of the above is done and some more in the Boonton 1120 using a Z80 in the mid-1980's. We can do much more today since the current generation of micros have lots more I/O's to work with and run much faster. I think the real questions would be whether the analog stuff is simply tunable filters for both the input and output to the ADC/DAC on the micro or if they need to be complete stand alone oscillator/notch filter elements.
Demian Martin
Product Design Services
Old 14th October 2013, 11:56 PM   #3173
rsavas is offline rsavas  Canada
I struggled for a bit with PIC and jal, then found BASCOM-AVR.
Started with a sparkfun xmega100 breakout board to get my feet wet,
I took the Elektor DSP radio article and went from there to design a complete radio/media player, a few years back now. Still am writing code for it today, 1000's of lines of code later and still going.
A few bourns rotary encoders, a 4x40 LCD display, sparkfun xmega100 breakout board and there you have it, a UI.
I can say for sure, you do not need C. The Atmel xmega MCU works really well. You can embed asm if you really need too.
There are however so many options to do the exact same thing.
Wonderful work Vladimir!! Since you share your designs, I can certainly help you with getting to my programming level. BASCOM-AVR has a free demo, but only costs 79 euro I think for a full license.
Rick
Old 15th October 2013, 02:28 AM   #3174
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
OK. Sounds like we have a quorum and volunteers to do the software. Which of you is IT!?
That leaves the other parts to be responsible to do -- volunteers for those parts are needed. I'll coordinate and follow and try to keep it flowing within individual time constraints.
An analyzer such as VKAudiotest did/described has the feature set I would want. That's what I am signing up for.
THx-RNMarsh
Old 15th October 2013, 02:34 AM   #3175
RNMarsh's Avatar
Oscillator level
frequency in
Throw in a distortion monitor port for visual and FFT and maybe a usb port?
MSRP? DIY Built for < 500 usd?
-RNM
Old 15th October 2013, 03:03 AM   #3176
jcx is online now jcx  United States
I wouldn't spend the time on local display - use a smart enough board to network to a PC that can run SciLab, iPython, scipy, ect.
Old 15th October 2013, 09:24 AM   #3177
RNMarsh's Avatar
I agree... FFT was to be via distortion residual monitor port as is done on many commercial thd meters.
-RNM
Old 16th October 2013, 07:18 PM   #3178
RNMarsh's Avatar
Hmmmmm. Lots of ideas but no one stepping up to share in the time to finish it off as a complete package.
So its back to my experience that you build what we have and known to work and performs. Then its easier to do a Ver 2.0 afterwards. Do the easy mods/updates on Ver 1.0.
Otherwise what are we doing besides talking and kicking the can further down the road.
Thx-RNMarsh
Old 16th October 2013, 08:14 PM   #3179
Thx-RNMarsh
That's kind what I was getting at Rick. There lot's a really good ideas but no one to step up and take the task. Everyone has a different ideas and flavor of technology.
David.
Old 17th October 2013, 02:17 AM   #3180
RNMarsh's Avatar
Does it really matter which way or which circuitry as long as it has the numbers we like it to have... and one which has been done already and is known to have the numbers and all the issues and bugs worked out already is a great place to start. Improve on it from that circuit. Ver 2 and ver 3.0 or something not proven will have to wait until someone else wants to do it first. We need someone's completed/tested/prototyped circuit to begin. A few have been proposed that are done via SIM. But, who is ready to show us a finished, completed schematic?
-Richard M.
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright 1999-2017 diyAudio
