Low-distortion Audio-range Oscillator - Page 30 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 4th September 2012, 06:05 PM   #291
1audio is offline 1audio  United States
I have that demo board as well. Let me reconnect it and compare the results.
Demian Martin
Product Design Services
Old 4th September 2012, 07:14 PM   #292
Default PCM4222 EVM
Here is the same source measured with the PCM4222 EVM. I did not get the same results or even nearly so as the linked test. Distortion products are higher. Key difference- I am sampling at 192 KHz. Changing the sample rate is a real PITA on these. I had to get the local FAE to get the board running and he had to call several people at TI for guidance.
It also shows me that I have some jitter in the on board clocking on the AKM board (its not well done and I should completely reconstruct it).
The noise above the oscillator frequency is lower than the noise below (??). The noise shaping start up at 50 KHz on this chip. I'll leave it running and recheck the distortion in a few hours to see if its better. I also need a better power supply for these guys.
File Type: jpg 1 KHz Distortion AG16B-2+PCM4222EVM.JPG (119.3 KB, 462 views)
Demian Martin
Old 4th September 2012, 07:19 PM   #293
dirkwright's Avatar
OK, thanks. I was planning on battery power. I'd be interested to know if there's a better ADC out there.
How did you get the signal into your computer? Did you use the S/PDIF RCA jacks or the AES jacks? I bought a miniStreamer from miniDSP that is a bidirectional I2S to USB link, since I only have USB available on my laptop.
Old 4th September 2012, 07:37 PM   #294
I'm using SPDIF coax to a Juli@ card. I am also using an external OXCO 24.576 oscillator with really low jitter. The Ministreamer would be a good choice. Those guys are very good. The demo boards support I2S and I think you can configure the Ministreamer so the clock schemes will work.
For ADC use there is very little possible difference between AES and SPDIF since the information is not time critical data like the DAC side.
Demian Martin
Old 4th September 2012, 07:54 PM   #295
richiem is offline richiem  United States
richiem's Avatar
RE PCM4222: Things I'm not crazy about -- that bundle of trash at around 48kHz, which has been an issue for me with the EMU 0204, too. Is that actually from the ADC? And the higher distortion with lots of products way on out....
Dick Moore
Old 4th September 2012, 08:12 PM   #296
dirkwright's Avatar
Someone mentioned the advantages of using balanced connections for test and measurement. I wonder if the balanced AES signal would be cleaner?
Also, how would I interface the balanced inputs of the evaluation board with a single ended circuit?
Old 4th September 2012, 09:31 PM   #297
dirkwright's Avatar
Maybe they were not enclosed in a good RFI proof box?
Old 5th September 2012, 04:08 AM   #298
Default RFI Shielding?
Not really. The generator is in the stack on the left under the aluminium chassis and the ADC is on the right on top of the Heathkit supply connected through 8 feet of coax. Its identical to the setup used with the AKM demo board. Neither are particularly good.
The big board in front is what I should be working on. . .
Demian Martin
Old 5th September 2012, 05:23 AM   #299
richiem's Avatar
The bundle of modulated spikes at 48kHz has nothing to do with EMI or RFI -- it's something from the ADC or the interface, and since I see the same thing in the EMU 0204 with a different interface, I think it's the ADC.
Dick Moore
Old 5th September 2012, 03:16 PM   #300
dirkwright's Avatar
Well, I doubt you're going to find something better that doesn't cost the moon. I've been looking at various sound cards and USB/Firewire interfaces for pro audio and none seem to have lower noise. The M-Audio and Focusrite products seem to be popular and well regarded, but don't know for sure. Do you have any suggestions for a better ADC/DAC? I checked National Instruments and they only have 16 bit interfaces.
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright 1999-2017 diyAudio
