Low-distortion Audio-range Oscillator - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 2nd February 2012, 11:20 PM   #21
Dirkw: I believe you are right. I also believe the pin-out of the LT1010 is wrong, pin 1 should be 2, 4 should be 2. Any comments? E
Old 2nd February 2012, 11:26 PM   #22
dirkwright's Avatar
I don't know yet, haven't had time to study it any more, just read through the application note this afternoon... so busy! Thanks for the tip. I am not talented at making circuit boards. I can do this on nice perf board, though 20volts output is way too much! I think I'd put a volume control before the input to the LT1010. Another problem is that the LT1006 is really only available in surface mount. I don't think ai can surface mount something on perf board.... can I?
Old 3rd February 2012, 12:06 AM   #23
I am thinking about designing the board for this oscillator once I am satisfied with..., also there are many suppliers of surfacemount to DIP adaptors
Scaling the output is not a problem. I am looking into replacing (or adding to) the LT1010 with a hi-slew balanced output device. E
Old 3rd February 2012, 12:09 AM   #24
dirkwright's Avatar
Oh cool. I'm in for a group buy. Balanced output would be fantastic!
Linear Technology sells the chips direct no problem, and apparently cheaper than Digikey.
Old 3rd February 2012, 12:25 AM   #25
Speedskater's Avatar
In the Williams circuit, sometimes that CdS photocell can be hard to find in any venders stock.
Kevin
Old 3rd February 2012, 12:29 AM   #26
davada is offline davada  Canada
Default CdS
Check with Jackinnj for the CdS.
David.
Old 3rd February 2012, 12:32 AM   #27
dirkwright's Avatar
It looks like this LT circuit has been discussed before:
Low Distortion Signal Generator
back in 2004.
Old 3rd February 2012, 12:33 AM   #28
dirkwright's Avatar
This looks like the animal we need:
Excelitas Technologies Sensors - VTL5C10 - Optoelectronics & Lighting - Optocouplers/Optoisolators - Allied Electronics
I ordered 3 of them. I can share with mickeymoose or whoever is serious about designing a board.
Old 3rd February 2012, 12:35 AM   #29
Random musings:
As low THD can be acieved only with low tol R+C in the Wien Bridge (stereo pot can have up to a +/-20% variation between segments), me thinks I will replace the dual-pot with a stereo digital pot and a small-value dual pot in series with the digital for in-between frequencies. Adjustment of the digital pot through a rotary encoder. This will require a digital frequency read-out, of course.....now this is getting involved! E
Old 3rd February 2012, 12:51 AM   #30
dirkwright's Avatar
Random musings:
It would be a lot easier to make if I can just find a dual pot that has matched sections.
I could put 2 of these together:
http://www.bourns.com/data/global/pdfs/6574.pdf
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright 1999-2017 diyAudio
