Low-distortion Audio-range Oscillator - Page 191 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 22nd March 2013, 03:59 PM   #1901
Another issue is that of resultion. I think that quantization noise would introduce significant sidebands/amplitude modulation. A rough calculation lead me to believe that > 16 bit would be required to keep quantization noise below the inherent amplitude noise of a (very) well designed SV oscillator. That's of course again a function of the multiplier decoupling/required settling time. The above number is based on < 10 s to 0.1% for a 100 Hz to 10 Hz range change and a multiplier authority similar to what's found in the AP System One. But that's all plain theory at the moment, I haven't implemented anything.
Samuel
Old 22nd March 2013, 04:37 PM   #1902
myhrrhleine's Avatar
Originally Posted by davada View Post
If we are talking about the SYS1 then the OSC has four 5534 including the multiplier.
Can't accommodate the two pole comp if going to 1468.
The output amplifier is discrete. It looks more like a power amp.
Is that 6-10dB of disto, noise or both?
Distortion.
The noise is very close to the same depending on exact impedance.
But the 1468 has more open loop gain more bandwidth and more linearity so lower distortion.
On the other hand the OPA 827 is a better choice for high impedance because it is FET input and so lower noise current.
And the AD 797 is best for low impedance.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 22nd March 2013, 04:46 PM   #1903
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Can you show me the Sys1 oscillator schematic - anyone?
Ill try the opa827 to see what happens compared to others tried.
Thx-RNMarsh
Old 22nd March 2013, 05:16 PM   #1904
1audio is offline 1audio  United States
You can download it here: AP High Performance Audio Analyzer & Audio Test Instruments : Home Starts Page 152. (I should have read it before assuming how the box works.) You need to register first. Its an OK scan of the service manual with all the details. You might have been better off servicing it yourself but you never would have gone down this learning path.
Demian Martin
Product Design Services
Old 22nd March 2013, 06:19 PM   #1905
davada is offline davada  Canada
Thx-RNMarsh
Just for a quick reference.
David.
Old 22nd March 2013, 08:26 PM   #1906
RNMarsh's Avatar
Default Lowest THD+N at 1-10KHz - for the KH4402B
Ok Thanks both for the schematic info. looks like a lot of 5532/34 opamps which can get upgraded.
Meanwhile, back at the bench -->The KH-4402B has now found an opamp combo that does better than either AD797 or LT1037 or LT1468 alone can do.
Replacing U125 with the AD797 and replacing U141 with the LT1037 now gives the same THD+N level at 1KHz and at 10KHz.
Namely,just under .0001% at .00008-9% at either 1KHz or at 10KHz.
This was done on the X1K scale.... just switching from 1 to 10 on the freq dial. But when using the X100 scale and dialed to 10 (1KHz) the THD+N is even lower -- .00005% :-)
Before, this combo the THD+N rose at 10KHz. Now it is steady at a low level at 10KHz.
[trim R145 AVC control at 10KHz]
Thx-RNMarsh
Old 23rd March 2013, 04:52 AM   #1907
RNMarsh's Avatar
Here is where we are now with finding and modifying an existing versatile low distortion generator -->
The 2H and 3H are 2.0dB above and below -140dB. No other harmonics show above the noise of -155dB.
Thx-RNMarsh
Old 23rd March 2013, 04:14 PM   #1908
The ad797 has much higher noise current and much lower noise voltage than a opa827.
Therefore if the ad797 shows noise improvement then the circuit is likely low impedance rather than high impedance.
So, the opa827 is likely to make things worse.
Old 23rd March 2013, 04:46 PM   #1909
Hi Rick,
Look for charts like this on the data sheets.
The one for the OPA1641 compares to the ultra low noise OPA1611.
The 1611 doesn't do nearly as well at higher impedance.
The 1468 covers a wide range of input R without the noise curve taking off which makes it ideal for wide range OSC tuning.
It would be pointless to use an OPA1611 or the like above a source R of 1K
Not all data sheets include this chart.
David.
Old 23rd March 2013, 04:58 PM   #1910
RNMarsh's Avatar
Samuel
This is exactly what is shown... a lot of spurious freqs other than random noise and harmonics of the test signal. It makes it pretty hard to find the DUT harmonic signals/levels from the system's spurious frqs. at low distortion levels.
A serious pcb layout R&D effort will be needed.
Thx-RNMarsh
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
