Low-distortion Audio-range Oscillator - Page 185 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 12th March 2013, 03:39 AM   #1841
davada is online now davada  Canada
Originally Posted by RNMarsh View Post
No I have not. Took a detour at the 725D exit off ramp. .
Are you making any headway with that one?
David.
Old 12th March 2013, 04:38 AM   #1842
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
It too has potential because of the older opamps used in many places. But need schematic to know what and where everything of interest might be. I have had no luck in finding a service manual for it. So I have that project on hold until I get a service manual.
_RNM
Old 12th March 2013, 09:54 AM   #1843
RNMarsh's Avatar
Default A-P opamp?
Originally Posted by dimitri View Post
Richard, they specify THD+N in 22kHz bandwidth:
Analog generator residual THD+N At 1 kHz _(0.00025% + 1.0 μV) [–112 dB], 22 kHz BW
Analog analyzer Residual THD+N: At 1 kHz _(0.00025% + 1.0 μV) [–112 dB], 22 kHz BW
Dimitri --- what opamp is used in the A-Precision's oscillator?
Thx - RNMarsh
Old 12th March 2013, 11:41 AM   #1844
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
AD797
Old 12th March 2013, 10:17 PM   #1845
RNMarsh's Avatar
Any tricks/recommendations to using it to full advantage in oscillator app?
Thx-RNMarsh
Old 12th March 2013, 11:35 PM   #1846
RNMarsh's Avatar
I mean beyond the literature and good practices. -RNM
Old 13th March 2013, 07:34 AM   #1847
The AD797 is probably not stable when used in a basic inverting integrator (or any other with substantial capacitive feedback) application. Don't know how AP solved this, but I have used a small resistor (150-220 Ohm) in series with the inverting input. If you can't stand the noise penalty, parallel the resistor with a wideband inductor.
Samuel
Old 13th March 2013, 06:55 PM   #1848
RNMarsh's Avatar
Ok... Thx SG. Thats what I am looking for -- practical app info. Not trade secrets.
I've seen buffers driving osc opamps input -- presumably to provide low source Z on the osc opamp input (?). But a small R ll L is easy to try if I run into trouble.
Thx-RNMarsh
Old 18th March 2013, 07:42 PM   #1849
Ite is offline Ite  Netherlands
Having zero experience with low distortion oscillators, but after reading this thread I was thinking that this could be a candidate for a detector.
Precision Envelope Detector with 0.032% Total Harmonic Distortion
It was mentioned a few years ago on the LTspice forum by Mike Monett
Ite
Old 19th March 2013, 08:46 AM   #1850
RNMarsh's Avatar
Well I recieved the AD797 today and went direct to the KH4402B and yanked the LT1468 and put the AD in its place as the oscillator. yes, i added the 50pf.
Here is the result in a nut shell --> The noise dropped about 6dB and the THD+N dropped 3-4 dB's from 1KHz to 10Khz. Not a huge change but I'll take it. The oscillator THD+N is .00009- .0001% at 1KHz and .00015% at 10Khz from the direct out from the oscillator port (7v rms). Adjust the 10-turn AVC trim pot (R145) for lowest THD at 10Khz.
The lowered noise floor is now showing me junk I had not seen before (like ps harmonics so i beefed up the filtering on the ps) and allows me to see the individual harmonics better.
Thx-RNMarsh
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
