Low-distortion Audio-range Oscillator - Page 174 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 9th February 2013, 05:33 PM   #1731
1audio is offline 1audio  United States
Originally Posted by davada View Post
No. A small dc offset on a loud speaker has absolutely no effect on the sound.
Actually it can. Cone drivers are not that linear and a small DC offset can move the voice coil enough to reduce/increase the distortion some. If you look at a Klippel plot you can see the source of the issue.
A small DC offset can saturate the transformer of a electrostatic speaker increasing the distortion a lot.
Demian Martin
Product Design Services
Old 9th February 2013, 08:22 PM   #1732
davada is offline davada  Canada
Originally Posted by 1audio View Post
The problems with the state variable filter used that way is the intrinsic distortion of the amplifiers and the tuning. That is the core of the analyzer in several analyzers, the Boonton and the Amber are two examples. The passive notch, like the B&K, are better. You could modify the B&K with active circuitry to make a tuneable high q notch with it. We just need to reverse engineer its circuitry, not a small task.
It's that complex?
David.
Old 9th February 2013, 08:28 PM   #1733
I meant smaller offset than that. Less than 1Vdc.
Electrostatics are another matter.
David.
Old 9th February 2013, 08:37 PM   #1734
It's that complex?
I did not think so until I pulled the cover off. The tuning element is a pot with switched caps and some other circuitry but its not real easy to follow in the box.
I'll post some pictures later.
Demian Martin
Old 9th February 2013, 09:23 PM   #1735
richiem is offline richiem  United States
richiem's Avatar
The K-H 4400 has a very low-Q filter, with not much notch depth. Not a good candidate i my opinion. Most oscillators use relatively low-Q filters for tuning. The 339 and 239 probably have the highest Q filters, but even so their notch depth would not be much over 30dB. None of the commercial oscillators I've seen use a Twin-T for tuning -- most use a Wien or bridged-T -- inherently low-Q.
Dick Moore
Old 10th February 2013, 12:08 AM   #1736
EssB is offline EssB  United Kingdom
Hi Dick,
I found a commercial Twin-T oscillator for you - the Radford LDO3 from 1975:
http://www.stancurtis.com/Soundtech/...%20Series3.pdf
Old 10th February 2013, 12:30 AM   #1737
Originally Posted by EssB View Post
Hi Dick,
Cool.
David.
Old 10th February 2013, 12:35 AM   #1738
.. but not so cool looking, more info at
Radford Low Distortion Tee-Twin Sine Oscillator
Old 10th February 2013, 12:43 AM   #1739
That one looks like it's been through a middle Eastern war.
David.
Old 10th February 2013, 12:46 AM   #1740
Default Twin T osc
It looks like there is a few of them out there.
Art's Theremin Page: Twin-T Audio Sine Wave Oscillator
David.
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright 1999-2017 diyAudio
