Low-distortion Audio-range Oscillator - Page 171 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 3rd February 2013, 07:54 PM   #1701
scott wurcer's Avatar
Originally Posted by davada View Post
Hi Scott,
I,m not clear about your meaning here.
You don't agree in-harmonic distortion in capacitors?
Non-harmonicly related distortion products can not exist, that is for two input frequencies the distortion products are only at A*F1 +- B*F2 where A and B are integers. I am speaking here of amplifiers and preamps, where this behavior is not observed, if you can present even one bona fide observation of this in capacitors hats off to you.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 3rd February 2013, 08:22 PM   #1702
JensH is offline JensH  Denmark
Regarding COG versus Polypropylene and Polystyrene this gives a lot of good information:
http://www.waynekirkwood.com/Images/...ap_Sound_4.pdf
It also shows that it is not just the material used that counts. Also the physical implementation is important. And the DC bias applied!
And I think all the notes from 1 to 6 are worth reading.
This also seems to support the thought that COG are excellent capacitors, but Polystyrene are slightly better:
Low distortion oscillator tests measurement circuits | TMW
Old 3rd February 2013, 08:22 PM   #1703
davada is online now davada  Canada
Well that really is just kind of the nature of things.
The same holds true for musical instruments.
David.
Old 4th February 2013, 02:48 PM   #1704
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Notice what happens with DC added to the ac thd..... increases of 20-30dB are common.... worse in electrolytics. Note too that asymetrical waveforms have a DC component.
I have measured thd with asymetrical waveforms and find with FFT that it was primarily 2H. Thx-RNMarsh
Old 4th February 2013, 04:34 PM   #1705
jan.didden's Avatar
Dick,
Doug Self maintains (and backs it up with measurements) that if you can keep the ac levels across an electronlytic below 70mV or so, the distortion is negligeable. That means that sometimes you need to use a much larger cap value that you would for the circuit time constants.
What's your take on that?
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 4th February 2013, 06:03 PM   #1706
myhrrhleine's Avatar
I am confused.
According to http://www.janascard.cz/PDF/An%20ult...0-140%20dB.pdf they are able to get -150db.
But according to Bateman the capacitors have a distortion closer to -130db.
Any one got ideas?
Btw I have looked and can't find Bateman's website.
His articles were around 2003 in electronic world
I do have them in pdf format that I can share if anyone wants them.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 4th February 2013, 06:21 PM   #1707
EssB is online now EssB  United Kingdom
Some of the Cyril Bateman pdf's can be downloaded from here:
Capacitor Sounds, Speaker Cables and Crossover Inductors.
I have one of his CDROMs if anybody needs anything else.
Old 4th February 2013, 07:18 PM   #1708
richiem is offline richiem  United States
richiem's Avatar
RE I am confused -- me too, but some of the issues here are the uncertainties of the measuring gear. These results are all near the residuals of the oscillators and analyzers. As such, the water is cloudy and not assuredly safe to drink.
Dick Moore
Old 4th February 2013, 09:04 PM   #1709
According to Chyba 404 - Stránka nenalezena they are able to get -150 dB. But according to Bateman the capacitors have a distortion closer to -130 dB. Any one got ideas?
Me too, but some of the issues here are the uncertainties of the measuring gear.
This is likely all just measurement limitations. The Bateman setup is accurate to probably about -120 dB (it's some time since I've read his articles, so with reservations), so any comparison for lower distortion capacitors is meaningless. The Janásek article is, as pointed out several times already, pretty naive with quoting results at the -150 dB level. It could as well have been that the Polystyrene cap has higher distortion than the C0G, and that the higher distortion just happend to better cancel the contribution of the notch filter.
Samuel
Old 4th February 2013, 10:49 PM   #1710
RNMarsh's Avatar
Samuel
I certaily would agree from the tests i have done recently.
Regarding ac level across caps as they were tested... Yes, keep the voltage drop across them as low as possible. This is easy to do in coupling cap apps. But in tone controls, EQ and filters, it doesnt work out quit so well. -Thx-RNMarsh
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
