| Equipment & Tools From test equipment to hand tools |
#1691 | |
Any volunteers?
David. |
#1692 |
If someone has a 1K Victor oscillator it is pretty easy to remove the red film caps and reinstall cogs there for a test.
Retirement-Never do today what can be put off until tomorrow. |
#1693 | ||
![]() At audio frequencies, only the two R and the basic C element are of importance. Any of these may show a voltage coefficient and thus contribute distortion. The exact physical explanation why the basic capacitance element exhibits a voltage coefficient is not clear to me either. One possible contribution could be that the electric field contained within the plates of the capacitor may slightly bend/displace the plates, and thus cause capacitance modulation with signal voltage. The leakage resistance is formed by parasitic elements of not well known chemical composition. These not necessarily follow Ohm's law (which in essence applies to metal conductors only) very well, and may show significant voltage coefficient. The ESR is at least partially formed by end contact resistance. Bruce Hofer points out in his "Building Analog in the 2010s" slides that, particularly for film capacitors, these may be unreliable and cause some distortion contribution. Which mechanism dominates depends very much on the circuit impedance, i.e. the corresponding R which forms the effective time constant. At medium impedances (1-10 kOhm), the basic voltage coefficient of the C element seems to be the most significant in my experience. Nonetheless, this discussion shows that you can't fully characterize capacitor distortion at a single frequency. Capacitor distortion should be measured at least at three widely spaced frequencies. Quote:
Samuel |
#1694 |
David. |
#1695 | |
Demian,
![]() HpW
www.hpw-works.com |
#1696 |
#1697 |
Just about anything-including electrolytics- measure well with symetrical waveforms (sine waves). In my 339A I have bipolar types in the signal path. Its a very INsensitive test. But with sine waves to get below -130 takes special care in cap selection and test equipment.
[ BTW- its with asymetrical waveforms (music) where the cap issues show themselves to measure and... sound poor. ] -Richard Last edited by RNMarsh; 3rd February 2013 at 04:23 PM. |
#1698 | |
Do you have one for a PP just for comparison sake.
David. |
#1699 |
As you know I don't agree with this anymore than in-harmonic distortion. Please describe an I/V characteristic of a capacitor that would show this behavior. The mechanical effect just quoted has a rectifying property (the force vs voltage is always anti-repellant) and will manifest on a simple sine wave. The extreme case would be the condensor microphone analyzed in detail by B&K.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 3rd February 2013 at 05:04 PM. |
#1700 | |
I,m not clear about your meaning here. You don't agree in-harmonic distortion in capacitors?
David. |
| ultra-low distortion audio oscillator | geekysuavo | Analog Line Level | 16 | 26th March 2013 03:04 PM |
| Radford Low Distortion Oscillator Series 2 | audiomik | Equipment & Tools | 19 | 21st January 2013 05:37 AM |
| Low distortion oscillator? | rjm | Equipment & Tools | 30 | 4th May 2011 10:45 PM |
| Can we improve this low distortion sine oscillator ? | gaetan8888 | Solid State | 22 | 29th March 2009 12:30 PM |
| Simple, low distortion 1kHz oscillator | jackinnj | Solid State | 4 | 6th October 2003 03:58 AM |
