Low-distortion Audio-range Oscillator - Page 146 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 4th January 2013, 06:47 PM   #1451
davada is offline davada  Canada
Originally Posted by dimitri View Post
Why not two of them in control loop: (A*sin(wt))^2+(A*cos(wt))^2)=A^2, no ripple (in theory)
Hi Dimitry,
I've been giving this some thought.
If the summed levels are out by 1% this causes roughly 165mV ripple.
If we use one output signal as a reference and use an AGC on the other output signal,
we might be able to make this work. But it will come with extra complexity.
If we do this with a Gilbert multiplier core, we have access to every part of the multiplier.
Once we get it right then look at some of the 'simpler to use' multiplier ic's.
David.
Old 4th January 2013, 08:47 PM   #1452
myhrrhleine's Avatar
Originally Posted by davada View Post
This is the circuit used and spectrum of the output.
For 6Vrms input to the lamp there is a 5.56Vdc output.
At 3Vrms the output drops to 0.823Vdc.
That's not very linear.
I'm concerned about the level of distortion as well.
This is with a 0.1uF feedback cap on the output amplifier.
I's much worse with out the cap.
R is 10M.
An ignorant question
dont you need at least 3 points to determine if it is linear or nonlinear?
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 5th January 2013, 12:31 AM   #1453
Lol.
Yes. I suppose a few more point would be better.
David.
Old 5th January 2013, 01:43 AM   #1454
1audio is offline 1audio  United States
Don't forget zero is part of this curve. More points help.
Demian Martin
Product Design Services
Old 5th January 2013, 05:42 AM   #1455
Okay I'll do a little chart tomorrow.
But the distortion and feed through is too high and I've lost interest.
David.
Old 5th January 2013, 05:30 PM   #1456
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
My take is this --- if you cut the input from 5.56v by exactly 1/2, the output should do same (2.78). It was way off at .823v and thus not deemed a worthy candidate. Have I got that right? -RNM
Old 5th January 2013, 05:44 PM   #1457
That's about it.
Now this could just be scaling and not necessarily non linear.
But I was here watching the points as they went by.
It was a poor communication on my part just to say it's non linear and I think this is
what was being said.
David.
Old 5th January 2013, 06:02 PM   #1458
If I could point a laser at the filament of the lamp and heat it this way I could control the resistance of the lamp by the Intensity of the laser.
It would have to be one big laser though.
David.
Old 5th January 2013, 07:13 PM   #1459
There is one approach to peak detection that I haven't ventured into and that is FFT.
Here is a complete project I found on the web which can be scaled down and modified for this purpose.
This is really quite cool. Coded for a PIC. I'm using the smaller pin version of this PIC to control the oscillator but I can upgrade to the larger pin count PIC. It looks like I need more pins anyway.
Since the peak value is not required to stabilize the loop, the lamps do this, this may be workable. The sample speed has to increase to cover a greater band width or we can just let it wrap around since it's a single frequency we know what that is.
We don't need the LCD driver code so that's a big saving there.
Check this out.
Real-Time Audio Spectrum Analyser - WFFwiki
David.
Old 5th January 2013, 08:01 PM   #1460
RNMarsh's Avatar
It doesnt look too unwieldly and a pcb is already made to try it with. Now... what is the goal, again? The cause of thd that this is going to affect a reduction? Just checking... sort of a resync operation. -RNM
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright 1999-2017 diyAudio
