Low-distortion Audio-range Oscillator - Page 143 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 2nd January 2013, 03:24 AM   #1421
davada is offline davada  Canada
Originally Posted by scott wurcer View Post
You don't want Ohms you want current.
Yes I know I don't want ohms.
I was just testing it with an ohm meter.
David.
Old 2nd January 2013, 03:38 AM   #1422
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Its an interesting approach and could be quit linear over the range of use. -RNM
Old 2nd January 2013, 04:22 AM   #1423
This is the circuit used and spectrum of the output.
For 6Vrms input to the lamp there is a 5.56Vdc output.
At 3Vrms the output drops to 0.823Vdc.
That's not very linear.
I'm concerned about the level of distortion as well.
This is with a 0.1uF feedback cap on the output amplifier.
I's much worse with out the cap.
R is 10M.
David.
Old 2nd January 2013, 04:39 AM   #1424
1audio is online now 1audio  United States
Here is another possibility-
Using a small micro (Arduino?) with an internal ADC or external ADC to detect the level of the oscillator output and then an internal DAC to send a voltage to the optical link that does the slow control loop for overall leveling. I'm sure linuxworks could tell us if the code is difficult and it could implement whatever PID is necessary to settle as fast as the system can.
One big reason that different frequencies will settle differently is the matching and balance of the R/C networks (and the GBW of the amplifiers). A really interesting possibility once you have a micro is electronic tuning. Using the micro for frequency detection and another 2 quadrant multiplier you could tune the system very precisely.
Demian Martin
Product Design Services
Old 2nd January 2013, 05:02 AM   #1425
I tried this with a PIC controller and found that they don't work very well for real time control. They work well for motor control but that is very low frequency.
The module timing for SPI transfer takes a while to set up and so I couldn't get a continuous stream of transfer. The processor is running at 48MHz. The SPI at 12MHz.
DSP I think would be a better approach.
Lt has a couple of high speed ADC which handle the timing for SPI transfer. So it's possible
to do a ADC to MDAC transfer with out a processor and there is no overhead in the timing.
I am planning MDAC tuning for this oscillator and that part will be controlled by a PIC micro.
The PIC is USB and there will be a Windows interface with a frequency counter, tuning and level controls. A cheesy Windows interface but functional. I'm not really a programmer but can do embedded in C.
The preliminary work with the PIC is done already. I just need to get the oscillator going
and that needs an AGC.
I'll try again with an LDR tomorrow and see how it goes. Failing that then I'll get some boards made up at a board house and get on with it.
David.
Old 2nd January 2013, 05:20 AM   #1426
My Boonton does the frequency trim through an optoisolated link. I get very good phase noise plots with it. If you have the local loop for stabilizing the oscillator then the control loop doesn't need to be very quick at all. For frequency they use JFET switches for both resistors and caps. Today I would use a controlled resistor array and switch the caps with JFETS. Then the final steering would be using a 4 Q multiplier. The PLL code would be the most difficult to get right.
Demian Martin
Old 2nd January 2013, 05:35 AM   #1427
Here is a digital volume control chip that could be used in a control loop for AGC (and frequency trim) http://semicon.njr.co.jp/eng/PDF/MUSES72320_E.pdf The opamps are external so its just resistors and jfets when used that way. Two to a chip so both functions could be managed. There are probably others that could work as well (and lots cheaper, these guys have an opamp thats $50).
Demian Martin
Old 2nd January 2013, 05:40 AM   #1428
The PIC has a 10 bit ADC and some are available with 12bit. This might be enough to set the level. 10 bit on 5V is 5mV resolution and 12bit is 1.3mV. The oscillator doesn't need to be sampled ever cycle to do this but we still need a fast sampler to capture the peak.
If the oscillator is running around 3Vrms then it fits into 12 bit over 10V for 2,5mV resolution.
David.
Old 2nd January 2013, 05:49 AM   #1429
Here is a cheaper solution: http://datasheets.maximintegrated.com/en/ds/DS1882.pdf These are non-volatile so the oscillator could start from where it last was set.
Demian Martin
Old 2nd January 2013, 06:07 AM   #1430
That would translate into .1% accuracy. It should be good enough as long as a local loop handles he primary stabilization.
Demian Martin
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright 1999-2017 diyAudio
