Low-distortion Audio-range Oscillator - Page 139 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 30th December 2012, 07:14 PM   #1381
davada is offline davada  Canada
Originally Posted by Samuel Groner View Post
If the controller has proportional action (and it needs this to be fast settling) there is by definition no (significant) low pass filtering. So glitches surely contribute some distortion.
Samuel
Hi Samuel,
Yes of course. I stated that wrong. So what I intend is not by definition proportional.
David.
Old 30th December 2012, 07:22 PM   #1382
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
We are not bound by others' faster settling times. We arent using this on a production line. Longer settling times than the norm are OK. [Not minutes, though.]
-Thx RNMarsh
Old 30th December 2012, 07:51 PM   #1383
-Thx RNMarsh
Well I was thinking more like hours.. No just kiding.
I agree this oscillator is not about fast settling just low distortion.
The settling time of the lamp is not annoying anyway.
100KHz is a bit trying but 10 - 20KHz is a couple of seconds and 1KHz down is less than a second. It might take a second or two more for an leveling circuit to bring it to a reference level. A fast AGC is the wrong thing for this. The lamps are simply to slow responding and cause oscillator squegging.
Another lamp might be just the thing. Does anybody know where I can find a low current miniature dual filament lamp?
One filament for heating and the other.....
David.
Old 30th December 2012, 07:57 PM   #1384
1audio is offline 1audio  United States
Its an automotive taillight. Quite a few choices.
Demian Martin
Product Design Services
Old 30th December 2012, 08:04 PM   #1385
Yes but the current is quite high. 2-3 Ampere.
I need the high heat to isolate from ambient T.
How about a lamp driven LDR assembly?
David.
Old 30th December 2012, 08:13 PM   #1386
They aren't made any more but would be easy to fabricate. At low frequencies you will get flicker.
A sample and hold is not really overkill since they can be done with a few integrated parts. The low frequency limits your options. My ac calibrator dumps the s/h for the 100KHz to 1 MHz range but I have not seen an alternative for 20 Hz and below.
Demian Martin
Old 30th December 2012, 08:45 PM   #1387
There is this.
Coupled with a lamp.
This can be connected to a Jfet input op amp.
The setup is the same as what Scott posted for the PV coupler.
Max current of 50uA and a resistor to set the V scale.
I have a 7220 lamps connected to an oscillator running at 10Hz and I don't see any flicker.
I know there is some there but it's not visible to the eye.
The ripple from a lamp is at fundamental. This will pass through an integrator after being compared to a reference.
The integrator will attenuate the ripple further.
This might work.
David.
Old 30th December 2012, 09:42 PM   #1388
I have the 7220 in series with a 100 ohm resistor.
Input to the series is a 600mVpp square wave.
The QA400 is connected to the vertical output of the scope.
The first shot is the output of the function generator and the second is the voltage across
the 100 ohm resistor in series with the lamp.
I've been trying to measure the tau of the lamp but no luck.
Also with a sine.The waveform is clean on the scope.
The ringing is from the QA400.
David.
Old 30th December 2012, 10:15 PM   #1389
I received the PV part and assembled a circuit on some veroboard.
The 339a worked fine. No settling problems so the part is plenty fast enough.
Easy to set up and worked as predicted.
However I could not null the distortion to what I get without it.
Best I could do was about 8dB higher in 2nd H.
So I don't see any advantage with this approach.
But don't through it away it was a non ideal insertion for sure and this may have an influence on the performance.
David.
Old 30th December 2012, 10:56 PM   #1390
scott wurcer's Avatar
Surprised you can't null the seconds, do you have exactly what you did?
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright 1999-2017 diyAudio
