| Equipment & Tools From test equipment to hand tools |
#1361 |
Eagle seems like it ought to be the greatest thing ever... but my vote on it is also
![]() I'll take a look at DipTrace. -Thx RNM Last edited by RNMarsh; 30th December 2012 at 12:33 AM. |
#1362 | |
David. |
#1363 |
Sure. What do you want for them?
David. |
#1364 |
Nothing, just PM an address and later tell us if it is useful.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#1365 |
This is the place I was referring to.
I see there setup charge has gone up. Used to be $12.00. This is a quote on 1 6x9" board double sided. If the solder mask was left off it would be $24.00 cheaper. I wonder then if it would be tinned? For a development board it would be better to not have a mask. Anyone heard of these guys?
David. |
#1366 |
"Thermocouples won't work since they generate DC from the heat instead of a resistance change."
A change in current is all we need. Maybe a resistor in series. Driving a virtual ground node??? Actually I got he idea for this multiplier from an old HP wide band RMS detector which used a pair of thermocouples in a vacuum tube. The one thermocouple is heated by the other converting an AC loop to DC loop. I'll look up the model number.
David. |
#1367 |
I found these at Digikey.
I wonder if they are the same as the Amperite resistors?
David. |
#1368 |
They look interesting but they are polarized and need .6V to turn on so they are most likely a semiconductor circuit. And no glow. .
The Ballast resistors date back to the early 20's. The HP3400 and HP3403 use dual thermocouples to measure AC voltage. You need a chopper amp to measure the voltage off of the thermocouple. Seeing the price for a basic vacuum thermocouple I would leave them to the standards guys. I have an assortment but it took years to gather them. Except for NIST and a few obscure devices everyone has moved to digitizing for precision AC measurement so the market for these has really shrunk.
Demian Martin Product Design Services |
#1369 | |
I can't find any of these ballast. The company was bought out and only make relays now.
David. |
#1370 |
Amperite - Solving your relay requirements since 1922
They seem to be still at it. You may need to call them. The linear current range seem large so they could be well suited to this task.
| ultra-low distortion audio oscillator | geekysuavo | Analog Line Level | 16 | 26th March 2013 03:04 PM |
| Radford Low Distortion Oscillator Series 2 | audiomik | Equipment & Tools | 19 | 21st January 2013 05:37 AM |
| Low distortion oscillator? | rjm | Equipment & Tools | 30 | 4th May 2011 10:45 PM |
| Can we improve this low distortion sine oscillator ? | gaetan8888 | Solid State | 22 | 29th March 2009 12:30 PM |
| Simple, low distortion 1kHz oscillator | jackinnj | Solid State | 4 | 6th October 2003 03:58 AM |
