Low-distortion Audio-range Oscillator - Page 117 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 15th December 2012, 10:06 PM   #1161
davada is offline davada  Canada
Default 339a Oscillator
I've done more testing of the oscillator and found that adjusting the level trim R30 to yield best distortion at 1KHz is not the best for 10KHz and 20KHz. Adjusting this trim forces the operating voltage level of the Jfet gate to change. Therefore it has become necessary to have one trim pot for each range so the trim can be set appropriately for that range. The difference between 1KHz and 10KHz / 20KHz is 20dB so this is worth going after.
The best way to to do this is to add a wafer to the range selector switch.
Does anyone know where I can find a single or double pole 4 position wafer that will fit the shaft and align with the existing wafers? It need not be exactly the same it just has to fit mechanically.
No amount of fudging with capacitors in the positive feedback loop has any positive effect.
David.
Old 15th December 2012, 10:32 PM   #1162
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
That looks pretty darn good. Nice update and switching idea,too. The switch wafer size looks somewhat standard so maybe finding a wafer wont be too hard. Thx -RNM
Old 15th December 2012, 11:15 PM   #1163
Hi Rick,
I just checked the lower two ranges and the oscillator won't run at all for what's best for 1KHz. It does run for the 10K range though.
Short of finding a wafer that will work.
Another solution is to tap the capacitors at the range switch for the AGC signal input. The ripple here is 45mVpp riding on 9VDC. Add a quad op amp to buffer and drive relays to switch in the trim pots. A simple and elegant way to do this.
Still a switch wafer would work, it's about the same work and cost. The circuit can be constructed on a perf board or such or make up a PCB.
Edit: A quad comparator, LM339 with open collector, would be better than an op amp for driving the relays.
David.
Old 16th December 2012, 01:57 AM   #1164
RNMarsh's Avatar
Default HP339A THD+N
Maybe trimming each R set inside rather than a seperate wafer? Reed relays? Using just the mods: for 1KHz (1 X 1000 dials) and the THD+N at 1.7vac output from the 339A is about .00028% (NO filters are in !)
But, when I change freq dials -the THD goes up to .001% (mostly H2). So I need to trimm for several freqs of popular interest, first.
Old 16th December 2012, 02:21 AM   #1165
Default A look at Victor's oscillator on the 339a
This is Victor's oscillator attenuated to 1Vrms.
Every now and then it breaks into parasitic oscillation.
I have two of these and the parasitic in the other is too much to use the oscillator.
The noise floor is high by comparison and the only harmonic speaks for itself.
This reads 0.00325% on the 339a meter.
David.
Old 16th December 2012, 02:23 AM   #1166
The plot
David.
Old 16th December 2012, 02:41 AM   #1167
This is the 339a oscillator under the same load.
David.
Old 16th December 2012, 03:26 AM   #1168
1audio is offline 1audio  United States
Try separating the AC feedback from the DC. I think one of the schematics I saw had coupling caps on some aspect of the FET. The AGC will change a lot as a function of the component mismatches in the notch networks. The AC linearization of the FET should be independent of the gain of the fet to some degree.
Demian Martin
Product Design Services
Old 16th December 2012, 03:33 AM   #1169
RM- Take the analysis output from the 725 into an FFT. The fundamental is 425 Hz (I think) regardless of the incoming frequency. The harmonics will line up at multiples of that with the noise essentially gone. If you are looking at harmonics its fantastic and easy to see the relative levels.A little fiddling and you can get the absolute levels of the harmonics. I figure anything below -130dB is not too important.
Its a shame the box is so big. I just don't have room on my bench so mine is in storage a lot.
Demian Martin
Old 16th December 2012, 04:27 AM   #1170
Oops. I keep forgetting to turn the 400Hz filter off when switching to the lower ranges.
The oscillator is running just couldn't see it on the meter.
Demian how would you go about separating the AC feedback from the DC feedback?
There is a particular setting for the feedback where all ranges are stable but this is not optimal for best distortion in each range. The answer is to have separate setting for each range. I can't fix this with simple equalization on the AC side of things so switching in four different trim pots for each range seems reasonable. The oscillator works fine for the residual of the 339a analyzer. But we are greedy and we want more.
David.
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright 1999-2017 diyAudio
