Low-distortion Audio-range Oscillator - Page 105 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 6th December 2012, 03:53 AM   #1041
davada is offline davada  Canada
Grounding the two chassis together cleans up one problem and creates another at the same time. The spectrum measuring off the notch filter fills with hash.
I' not sure how to approach this problem. Batteries anyone?
The 339a oscillator and analyzer are isolated from earth ground and the outer chassis is earth grounded. Anything that connected to the 339a that is earth grounded drives the analyzer nuts raising the noise and probably causes oscillations.
One big isolation transformer to power all our test equipment including our computer would solve the problem.
A laptop would help since it doesn't require earth grounding.
David.
Old 6th December 2012, 04:27 AM   #1042
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
1. use an individual isolation/filter on each piece of equipment..... keeps equip to equip isolated from RFI. Put ferrite cores on ac power cords. And, float ac grounds. That's what I am doing.
2. The new replacement, wide-band opamps may be oscillating. Get a o'scope to look at output, power supply, etc?? Also look at the QA400 for oscillations on and from it.
I'm not having those problems here.
Old 6th December 2012, 04:43 AM   #1043
richiem is offline richiem  United States
richiem's Avatar
Rick, your results are just terrific, and I will do these things when 339A time rolls around for me. I will patiently wait for David to roll up his mods with a list of changes, then do it all at once. Thanks to you both for leading the way on this. David, I very much like the idea of swapping the order of the X100 amp and the filters -- I don't think the THD of the filters will affect the measurements.
I had written off HP's Bridged-T circuit because the clone of it I put into my old 334 gave me the same strong 2nd and 3rd H spurs as I found in the 339, and I used good new parts in the clone. Now I have to rethink this whole experience.
For meter readout, my money is still on an auto-tuned active Twin-T -- basically an HP 4333 with opamps and first-class parts. If you don't know that analyzer -- it was the bridge between the 334 and the 339 -- the manual is available on line, maybe at Agilent or one of the other sources of free books. I can't remember now where I got it.
Dick Moore
Old 6th December 2012, 05:01 AM   #1044
Floating the grounds will do it and that explains the absents of any ground problems.
There is still the issue of the earth ground via USB on the QA400.
Just for me try connecting something that is not ground floating and see if you get the same. Dick says he doesn't have these problems. My 339 maybe faulty.
David.
Old 6th December 2012, 05:03 AM   #1045
1audio is offline 1audio  United States
David:
Your QA400 is connected to a PC of some sort. That PC is in turn connected to power (unless its a laptop on battery). Whenever I use anything like that near low noise circuitry the leakage from the switching supplies around the loop(s) becomes the dominant noise. If there is a speaker or headphones its usually audible. I end up running the laptop on batteries in those conditions.
I have a 7L5 (and other similar tools) but no HP339 (and I do have 9 other distortion analyzers, just never added one of those). If someone near me wants to explore I would be happy to see what is happening.
Filter distortion- on my Boonton's the high pass filter kicks up the 2nd harmonic a lot when its engaged. I have tried the usual tricks with no success. I need to try the wonder opamp to see if it helps. The AD797 made no change. I think it may be a common mode issue. I believe the signal is at 1V at that stage. In the Boonton the filter is in front of the notch filter so its especially sensitive to the added distortion. is that a potential issue in the HP339?
Demian Martin
Product Design Services
Old 6th December 2012, 05:12 AM   #1046
These problems existed before any component changes. Nothing new from the mods.
Ill try floating the scope ground.
David.
Old 6th December 2012, 05:22 AM   #1047
Originally Posted by 1audio View Post
David:
Hi Demian,
The filters in the 339 are just before the x100 amplifier which feeds the meter's RMS convertor. This is far downstream from the notch filter. All the signals in the 339a are attenuated to 10mV and then amplified with a gain of 100 post filtering and normalized to 1Vrms FS for the meter.
Taking the signal from the output of the notch filter doesn't exhibit any of the mentioned problems. These only effect the meter and monitor output.
David.
Old 6th December 2012, 06:57 AM   #1048
dchisholm's Avatar
Originally Posted by davada View Post
. . . I also have access to an RF spectrum analyzer at work but it is 50 or 75 ohm input Z. That's a hard load for what we have. . . .
I have had some success just sticking a suitable resistor in series with the spectrum analyzer input. Something between 1K and 10K soldered to the center conductor on the "business end" of a short piece of coax, with about 1/2" of hookup wire connecting the coax shield to the signal ground point closest to where I wanted to measure. The free end of the resistor is your measurement "probe", though for best results I'd tack-solder it to the point I'm measuring.
The attenuation is pretty fierce, but spectrum analyzers can get down to the microvolt (or less) range if you know how to set up the bandwidths and sweep rates.
Yeah, this destroys the spectrum analyzer's amplitude calibration but you can still see frequencies, sideband structure, etc. And you can still do relative, before-and-after kinds of measurements to determine whether some change improves, or degrades, the signal you're looking at and by roughly how much.
It also helps protect the spectrum analyzer input from DC voltages, since the typical RF instrument is rather intolerant of DC at its input.
Several incarnations ago this technique helped me track down the source, and the injection mechanism, of some troublesome noise on power supply lines. (This was before half the 'scopes on the market had built-in FFT features, though I don't know if that would have helped since I was looking in the HF/VHF range.)
Dale
Old 6th December 2012, 07:06 AM   #1049
I would make a small coil of maybe 10-20 turns on a 1/2" to 1" former as a pickup. Couple it directly into the 50 Ohm cable (the mismatch won't matter). If there is something in distress it will radiate and the coil will pick it up. You could sniff all around the box to find the unhappy parts and no electrical connection to make a mess of things. Also good for getting depressed about power supply radiation and how its nearly impossible to eliminate.
You can buy these coils but they are way expensive.
Demian Martin
Old 6th December 2012, 11:22 AM   #1050
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
I'm using active probe with 50 Ohm output impedance, then
high-pass filter to remove audio, then
preamplifier, if required, then
spectrum analyzer or scope
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright 1999-2017 diyAudio
