Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 3rd December 2012, 06:13 PM   #1001
davada is offline davada  Canada
Originally Posted by RNMarsh View Post
Your on a roll.
I noticed there are electrolytic caps and trimmer controls that are not part of any feedback... for example the trim controls dropped thd by 6 db when replaced by better parts. Now, I see a pair of tantalum caps back to back as coupling caps. Well, that configuration reduces the cap distortion BUT we are after thd levels below what tant caps back to back provide.... I replaced the two tantalum back to backs (A3 C206,207) with a small 50v film cap and the third harmonic dropped another 6dB. No opamps have been changed, yet... waiting for adapters for the IC's to be mounted.
The THD (source plus analyzer) is now already 25 db below the -80db Full Scale, so we need a meter switch for X10 or -100dB F.S. range. When the opamps are changed, this will be more feasable (with the lower noise and distortion). Just need to trim the 2H down to much lower level. -Thx RNMarsh
I get the same on this 339a but only in certain settings. I wonder why. Try this in the overlapped next multiplier range. Like x100 at 10 on the left dial for 1 KHz and see if you.
get the same. Also try stepping the input range down 10dB and see if you get the same.
To have 1Vrms into the input of the notch filter you need to input -10dB of oscillator level.
Remember the input amp of the analyzer kicks everything up 10dB.
David.
Old 3rd December 2012, 11:12 PM   #1002
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Perhaps dc into the LDR will change with range switching caused by dc offset on the opamp outputs to vary to the LDR. Perhaps another cause of thd. Need to check. -RNM
Old 3rd December 2012, 11:53 PM   #1003
1audio is online now 1audio  United States
The ST1700A does the same thing with internal distortion limits moving with input level and range. Not an issue when the DUT is .1% THD. Big issue when the DUT is .001% THD.
The QuantAsylum guys were quite responsive and helpful.
Demian Martin
Product Design Services
Old 3rd December 2012, 11:56 PM   #1004
richiem is offline richiem  United States
richiem's Avatar
Rick -- note that the quad amp used by HP for the filters is a real stinker noise wise, and will need to be replaced with something much quieter if you're going to get lower distortion readings on the meter.
Dick Moore
Old 4th December 2012, 01:22 AM   #1005
RNMarsh's Avatar
Default Noisy IC
Yes, i believe this is so, also. We had noticed this early on. i have the replacement quad IC ready to go into it. in fact, I'll do it now. Thx-RNM
Old 4th December 2012, 01:36 AM   #1006
RNMarsh's Avatar
Possibly requiring ac/cap coupling to the LDR (?) if it is dc sensitive (THD).
Old 4th December 2012, 01:36 AM   #1007
scott wurcer's Avatar
Default Rudolph the red nosed oscillator
Cleaned up my supply and added trims on the notch (>70dB). First the AD797 and second the AD844 just in case you thought a CFA would not work here. I suspect the thirds are down to the lightbulb's residual. This is a great find for anyone that simply want's to spot check a design, 30dB better than the 327 lamp oscillators that I built 20 yr. ago. There are two spurs left from my display drivers (easily ignored). It does take 10 or more seconds to settle, this goes hand in hand with the distortion. The correction is add 10dB to seconds and 5dB to thirds.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 4th December 2012, 01:47 AM   #1008
Does the color of the lamp matter?
David.
Old 4th December 2012, 02:08 AM   #1009
I'd say probably not.
Old 4th December 2012, 02:48 AM   #1010
Default ocillator
Have a close look at where the 2nd H is now. This is at the expense of higher frequency performance. The distortion at it's best at 1KHz and 1Vrms into the notch filter.
I forgot to mention, in the list of what's been done, I put a 50k trim across A3R48 and trimmed the total R to 10k. This forces the LDR to operate at a lower resistance much the same as putting a trim in series with the LDR. It has the same effect.
New stuff.
I removed capacitor A1C46. Cut the trace at right at the pin5 of A1U1 and added a 33 ohm
cheapo $0.06 carbon composite resistor in series with pin 6 and the output trace.
Tweaked the Jfet distortion trim and this.
I'll see if I can fix the high frequency performance with out losing the 1KHz.
David.
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 19 21st January 2013 05:37 AM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2013 diyAudio
