Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 24th January 2012, 05:43 PM   #11
If the ends of travel show near 0mil and you read -3 +5mil in the middle of travel then your direction of travel is not straight. That is likely to be a non flatness of your reference side. Did you check it with a straight edge?
I can see 1mil of out of flatness using a good condition steel straight edge.
The other reason for the wonky travel is a poor XY table. I have no idea about measuring the tolerances of an XY table.
But, if you can get a line of holes straight to within a couple of mil then you will have no problem gets the bolts to line up from the matching machined part.
If you were making a clock mechanism only 2000mil by 2000mil, I would expect you to work to tighter tolerances.
regards Andrew T.
Old 30th January 2012, 02:31 AM   #12
Lavcat is offline Lavcat  United States
Lavcat's Avatar
There is no precision surface on the side of the table to indicate on, which may explain the numbers, but now I have mounted and squared the vise. Using a laser (and this is the first time I have tried using a laser for alignment) I got within 5 mils. Then using a dial gauge I got it within 5 tenths, which is about as good as I can measure.
My setup was to put a large parallel in the vise and indicate along the vertical surface of the parallel. Do folks think this is a valid method?
Question - DCX crossover alignment jtalden Digital Line Level 0 29th March 2010 02:33 PM
A quick, dumb question on time-alignment Cloth Ears Multi-Way 4 25th September 2006 07:17 AM
Any DIY machinists here ? Elkaid Parts 10 23rd September 2003 06:19 AM
Time alignment question Simon Multi-Way 29 23rd September 2001 07:46 PM
Page generated in 0.07951 seconds (73.53% PHP - 26.47% MySQL) with 10 queries
