| Equipment & Tools From test equipment to hand tools |
Can anyone recommend some tools for my first DIY project.
I was planning to build a class t amp LM3875 from audiosector.com, could anyone recommend some tools to built my 1st project. Im starting from scratch and want to keep a tight budget. Heres some suggestions Soldering iron Multimeter Solder Is there anything else i will need, Thanks for your help |
#2 |
Hand tools, wire cutters, long nose pliers wire stripper.
Your local Maplin will have what you want. Or Maplin Electronics : Sale Now On
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Thanks for your reply, i just need some help choosing a soldering iron?
Do i go for a cheap Weller 25watt mains powered soldering station at £18 will this be adequate for the job?? http://www.amazon.co.uk/Weller-Sp25L...7086637&sr=8-1 or spend more and get a soldering station like DURATOOL|1296771+5090726+1467280|KIT, SOLDERING ST+WIRE+CLEANER | Farnell United Kingdom or for a little more at £40 Buy Soldering Stations RS DS50 Digital Soldering Station eu/uk RS DS50 online from RS for next day delivery. |
#4 |
I am also interested in the answer on the above question.
I am also just starting and want to get a complete set of tools I need (so the little time on the weekends I have -- I will not spend searching for local overpriced tools/components) I would also appreciate the advise from this board -- not just on tools -- but on components from wires to capacitors/transformers that I could slightly stock up on -- for a first timer who will get things wrong. To the original poster, I sofar found this article -- but this board will probably have lots more suggestions/etc Getting Started in Audio DIY |
#5 |
This discussion has some good pointers for beginners:
Wannabe electronics geek The Tangentsoft website linked in "worker's" post (Getting Started in Audio DIY) is excellent. His CMOY amp instructions are great! Excellent confidence booster and learning aid. Build a CMOY headphone amp for starters. Great first project. And excellent tutorial videos on his site. Good luck! |
| 1st diy amp kit | MarkL1 | Chip Amps | 15 | 9th January 2012 01:52 PM |
| help needed for 1st DIY tube amp - Sakuma 845 SE | glower | Tubes / Valves | 18 | 24th September 2011 03:17 PM |
| DIY Tools | Alai | Equipment & Tools | 7 | 1st April 2009 03:30 AM |
| my 1st diy tinny TDA1554 amp! help me.. | deepanger | Solid State | 6 | 22nd November 2002 01:24 PM |
| EL34 vs. 6L6GC for 1ST DIY Tube Amp? | pjkunz | Tubes / Valves | 4 | 17th December 2001 02:51 AM |
| Page generated in 0.08924 seconds (78.44% PHP - 21.56% MySQL) with 10 queries |
