| Equipment & Tools From test equipment to hand tools |
#51 | |
My B&K 4145 mics capsules are unpolarised capacitor mic that needed a 200V polarisation voltage, but I don't have anymore the power supply/preamp buffer. Would you have or know any schematics of transistors power supply/preamp buffer for my 4145 ? Thank Bye Gaetan Last edited by gaetan8888; 16th December 2011 at 08:12 PM. |
#52 |
Hi Gaetan,
Not off-hand. I haven't done any research on this. The unit I have is a tube type unit I think. It may in fact have such a supply built inside. I could have a look for you. I don't know if you're interested in it. A low noise 200 VDC supply is not hard to build either. I have some HV regulators I have designed that work well. Let me know if you want anything like that. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#53 | |
Now I remember, the 2601 was a tube microphone amplifier. Yes a simple 200vdc reg would be usefull. I've just found a circuit on the web, with different voltage it may work with my 4145 ? Thank Bye Gaetan |
#54 |
Hi Gaetan,
No, let's do something a little better than that. I'll try to find some diagrams for you and send them off. They work and I'll tell you what the performance is like along with the trade-offs I made when designing them. Hint: I go for low noise before tight conformance to a certain voltage. The changes in voltage occur as a slow drift to a final value that is really a temperature effect. Keep it cool and you get very little drift. These will all be things that exist in real life and have been working fine for some time now. My guess is almost zero current draw. Is there a tube amplifier stage in those mics? If you're interested in the 2601, I'll trade for something - you cover shipping. I'm thinking that I am not that attached to it, but you might be. I'll send a photo to you. -Chris
| Any pretty good/bad chinese amps? | S.Spielbergo | Tubes / Valves | 159 | 20th October 2011 08:07 AM |
| Fluke 8502A? | nania | Parts | 5 | 22nd May 2010 03:29 AM |
| Get a Fluke DMM | ThSpeakerDude88 | Parts | 107 | 21st August 2007 12:40 AM |
| WANTED: A good translation of the following Chinese DIY article | EchiDna | Digital Source | 14 | 30th July 2002 03:37 AM |
| Page generated in 0.07956 seconds (85.31% PHP - 14.69% MySQL) with 11 queries |
