| Equipment & Tools From test equipment to hand tools |
#21 |
Hello,
To understand more easily and more faster the overall EPSUX3 structure, i've draw a simplified synoptic. It show only functional blocks, that you can find on schematic for more details. Regards. EPSUX3V1 Synoptic. Frex.
DIY CS5381 ADC / DIY 10kHz Super Oscillator / DIY DC-1MHz RMS-DC converter & 60dB LNA . |
#22 |
Looks good Frex.
![]() Question, why did you design the flyback transformer? because the three outputs? or better specifications, quality? And the enclosure don't need a small cooling vent? Last edited by carpin; 22nd January 2012 at 05:10 PM. |
#23 |
Hello Carpin,
I design the transformer because you can't find already build transformer with your own specs ! Designing and building it is not a big problem for me. I don't think that the case will need a fan. The enclosure is in extruded aluminium and it's thermal impedance is good. Of course, only final tests at maximal power will verify this. Regards. Frex
#24 |
Hello,
The full design is well advanced and the flyback transformer is now soldered and tested on the final board, and fully functional. I have done many tests on the flyback, including measurements of efficiency vs Pout and vs Vline. I have tested the short circuit and open loop conditions and thermal behaviour of power parts. I will post complete graphs results tomorrow. Some little modifications has been done (parts values) to optimise it. Front panel is now also drilled. You can show the design progression on pictures below. Frex ![]()
#25 |
#26 |
Nice work! Superbly professional.
Any ripple vs load and voltage deviation vs step load measurements? |
#27 |
Hi Tazzz,
Thank you for your comments. These measurements are made on the flyback outputs, not final PSU outputs. But yes, i will perform others measurements on the real PSU outputs, like ripple voltage and a 0.5A/1.5A load step transient response. That's not yet finished ! FRex
#28 |
Good specs
No usb port for logging? |
#29 |
Hi all,
The PSU project is still in progress. The front panel has been drilled. No big issue has been encountered during mechanical mount. The green plexiglass of the leds displays is too dark, i must find another. I've also started to do some quick noise measurements, that show about 20 mV with a purely sinusoidal profile. I must d build a serious measurement setup to do these measurements with good confidence. Frex
#30 |
Hello,
Some pictures of how it looks like now. Frex (it's an AA battery at left for size comparison) ![]() ![]() ![]()
| I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. | Buckeye | Solid State | 48 | 26th May 2012 07:06 AM |
| Project 100W MJ15003 MJ15004 | Risto80 | Solid State | 7 | 1st July 2007 11:08 PM |
| Project 100W MJ15003 MJ15004 | Risto80 | Car Audio | 2 | 26th June 2007 02:41 PM |
| Chicago Standard BO-14 100W outputs | dshortt9 | Swap Meet | 1 | 10th August 2004 04:25 AM |
| Switches - Dual Triple Pole, Triple Throw | jackinnj | Swap Meet | 0 | 27th January 2003 07:18 PM |
| Page generated in 0.10198 seconds (81.33% PHP - 18.67% MySQL) with 11 queries |
