Triple outputs 100W Laboratory PSU -- A new DIY project . - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 13th December 2011, 05:42 AM   #11
Frex is offline Frex  France
Hello,
I work hard on the PLD program writing, about 75% of the job is done now...
The voltmeters works fine.
I will post another demo video when PLD will be ready.
And happy to see you here Carpin !
Frex
Old 26th December 2011, 03:22 PM   #12
6M9 is offline 6M9
Hi Frex,
Very professional looking design,
It's clear that you have put a lot of effort in designing this PSU.
Old 26th December 2011, 06:34 PM   #13
Hello,
Thank you 6M9, i just try to build PSU that fit well for my need with my own user feedback.
The CPLD program is now ok at 99%, i just need to use the internal EEPROM for record the last U/I settings for restoring these values at next strart-up.
As soon it's ok, i start to build the tranformer and test the flyback converter.
Some pictures or video will come...
Frex
Old 30th December 2011, 07:36 PM   #14
Hello,
As promised, a small video that present how work the EPSUX3 now.
Good watching !
To follow...
Frex.
Old 30th December 2011, 08:39 PM   #15
carpin is offline carpin  Netherlands
carpin's Avatar
Frex I can not watch the video.
It says
This video is private.
Sorry about that.
Old 31st December 2011, 06:38 AM   #16
Sorry,
problem solved.
--> Video
Frex
Old 1st January 2012, 04:10 PM   #17
carpin's Avatar
Looks good Frex, I like the one knob adjustment and the green/red over current indication.
Are you waiting for the transformer? i see a empty space on the PSU board.
Old 1st January 2012, 04:25 PM   #18
Hello Carpin,
About the flyback transformer, i will build it in next week.
Frex
Old 16th January 2012, 04:22 PM   #19
The flyback transformer prototype has been wound.
I test it's "real life" specs in the week with an "on the fly" test board.
The primary is split in 2 for lower leakage, and secondary windings are
winding at same time for maximum coupling.
I use Litz wires for secondary, but multiple small wire could work too.
In/out parasitic capacitances are neutralized with two copper shields between primary/secondary sides.
The shunt copper layer outside the transformer core that reduce radiated EMI will be added only
at the end( transfomer fully characterised).
Frex.
Old 21st January 2012, 11:57 AM   #20
Arrow PSU resonant flyback of EPSUX3 first tests!
Hello,
I have made many tests with the prototype transformer and first results are very good.
I reach the full output power of 115W without problem at expected switching frequency with an overall efficiency of about 85%.
The "on the fly" circuit board for testing the transformer looks like this :
You can see below the voltage waveform at the Drain of primary switch(green),
that showing the turn-on near 0V confirming ZVS. The output voltage of one of the three outputs is in yellow.
Here, it's the start-up sequence (yellow= output voltage, green Vds primary switch):
No excessive heat has been observed during max output power for long time, confirming
good transformer design.
I will now made several tests on it to define efficiency and loss charts, test it in short circuit condition, open loop and more. I will do also losses map.
all results will be posted.
I recall that the scheme is available HERE.
The old video demo of the front panel in working of EPSUX3 can been see HERE.
Comments welcome !
FRex
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. Buckeye Solid State 80 22nd March 2017 07:15 PM
Project 100W MJ15003 MJ15004 Risto80 Car Audio 6 13th April 2014 05:29 AM
Project 100W MJ15003 MJ15004 Risto80 Solid State 7 1st July 2007 11:08 PM
Chicago Standard BO-14 100W outputs dshortt9 Swap Meet 1 10th August 2004 04:25 AM
Switches - Dual Triple Pole, Triple Throw jackinnj Swap Meet 0 27th January 2003 07:18 PM
Copyright 1999-2017 diyAudio
