Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 20th November 2011, 06:04 PM   #11
davada is offline davada  Canada
Originally Posted by Conrad Hoffman View Post
Long ago National Semiconductor published an app note for building an FET curve tracer to work with a 'scope. It you have a scope it's a worthwhile thing to build, though it only does small signal FETs. It gives a single curve, not a family like the Tek and other tracers do. I don't think the circuit is on-line anywhere, at least I didn't find it, but I can probably dig it out and scan it if anybody's interested.
Hi Conrad,
Please do.
Cheer,
David.
DB
Old 20th November 2011, 06:14 PM   #12
Hi Conrad,
Was it anything like this?
Curve Tracers
We used this in school for demonstration a very long time ago.
David.
DB
Old 20th November 2011, 06:15 PM   #13
And this
DB
Old 20th November 2011, 07:18 PM   #14
Ian Fritz paper was just linked to today here
matching 2N4401
I think this BJT matching method transfers to jFETs.
regards Andrew T.
Old 23rd November 2011, 03:58 AM   #15
Here's the National circuit. For educational purposes, so hopefully it falls under fair use. I've built this and it works well.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 23rd November 2011, 08:48 AM   #16
Ian Fritz matching jig works with jFETs.
I changed the Vds diode to an LED for a higher Vdg of ~ 1.8V instead of 0.6Vdg
I reduced the pair of 100k to 10k+-0.05% to allow for much higher drain currents in k170bl.
These source resistors could go much lower yet, maybe down to 1k+-0.05% if you require matching at 5 to 10mA.
DUT takes a bit of time to settle to the same temp as REF.
regards Andrew T.
Accuracy of 2SK170 matching for JFET BOZ? Dr.H Pass Labs 6 22nd June 2011 07:12 PM
Matching jfet at what voltage? Sunsun22 Solid State 3 29th July 2010 11:57 AM
Ono JFET matching AuroraB Pass Labs 12 26th July 2007 12:20 PM
JFET in-circuit matching Leolabs Solid State 5 9th April 2006 01:44 PM
JFET matching Nelson Pass Pass Labs 19 19th February 2006 03:31 AM
Page generated in 0.08210 seconds (83.33% PHP - 16.67% MySQL) with 11 queries
