| Equipment & Tools From test equipment to hand tools |
I am looking for a temperature chamber:
- Temperature range wider than -40C...+85C - Interior size 8"x8"x8" or bigger - No CO2 Any suggestions |
#2 |
Thermotron S1.2 , 16 x 11 x 12"h, -73° to +177°C 120 volts
Thermotron S1.2 Mini-Max Freezer | eBay |
#3 |
Thanks a lot.
This is too big: external dim:26" tall, 36" wide, 21" dip |
#4 |
We use these guys at work, though not the model shown on the first page. They're built well and support is excellent. No chambers are going to be cheap and used chambers are a gamble unless from a well known vendor who backs them up.
I used to be an audiophool like you but then I took an arrow to the knee. |
#5 |
World's Smallest Temperature Chamber
Article. Temperature Chamber features 12 x 8 x 9 in. interior., TestEquity LLC Product. TestEquity 105A - Half Cube Benchtop Temperature Chamber - TestEquity Specs. Half Cube Model 105A Benchtop Temperature Chamber Specifications - TestEquity They also rent. Last edited by RJM1; 8th November 2011 at 05:44 AM. |
#6 | |
16.5" W x 26" H x 25.25" D (419 x 660 x 641 mm) Door latch adds 2" (51 mm) to width. Looking for twice smaller. |
#7 |
Hi myron.
You state 8"x8"x8" for internal dimensions. What are the max external dimensions you require? Also is this just the chamber size or including heating and cooling section too Regards Ian Last edited by madtecchy; 9th November 2011 at 07:06 AM. Reason: addition |
#8 | |
I would say max external dimensions 20"x15"x15" including heating and cooling section. It seems my state for internal dimensions is too optimistic. Thanks |
#9 |
Getting hot is easy. A large electric heater is all they use. Getting to cold - really cold - requires a 2 stage compressor - 2 motors. So the resultant size is big. We have a Thermotron at work that needs 230V as well. Didn't know 120V was a option for the smaller ones.
| Perfect sound search, this idea, HELP!, the long and insane search... | destroyer X | Solid State | 72 | 9th December 2008 05:55 AM |
| Page generated in 0.09413 seconds (76.95% PHP - 23.05% MySQL) with 10 queries |
