| Equipment & Tools From test equipment to hand tools |
#41 |
#42 |
#43 |
This adapter you listed will also fit into a 6-20R outlet as those outlets accept 15 or 20 amp plugs. Then all you need to do is fabricate an extension cord. It will not provide ground on a German plug though so you are just better off cutting the plug off and replacing it with a NEMA plug.
As I mentioned before, check the frequency on the nameplate.
#44 | |
Split-phase electric power - Wikipedia, the free encyclopedia But since this is an apartment building not a single family residence I am not sure. I have a meter, an old Radio Shack analog meter. Actually I have two of them. But I don't have a meter that I would trust to measure possibly two phase AC. I've been looking at extension cords. Found a 20 meter Schuko extension cord, but not from a US supplier. As long as I were willing to build the cable myself it looks like a NEMA 6 to Schuko might be the least expensive solution. Two disadvantages are that I would have a thick cable running through my living room that I would probably fall over, and I could not operate the air conditioning at the same time as the drill press. The transformers I linked still seem like a better deal for less than $100 delivered. The Proxxon faceplate says 230 V 50/60 Hz 300 W. The motor is a DC motor, not AC. |
#45 |
Ok, then you will be fine running that on 60Hz. Any of the meters that you have will be fine to test voltage at the outlet. Since the strp up transformer will be basically running a power supply and not the motor directly then anything that will convert 120 to 240 at 300 watts and up will be fine including the one that you listed. $100 is a good deal for it if I remember that is what you said it was and that will get this running for you.
#46 |
Thanks. I'll plan to update with my experience when I get it working (which will be sometime after I acquire a suitable workbench top on which to put the drill press). I really think the transformer is the better option. The US Consumer Product Safety Commission has a fact sheet on extension cords: "A 65-year old woman was treated for a fractured ankle after tripping over an extension cord." I figure she was probably covered by Medicare whereas I have two more years to go! And, speaking seriously, I've had two bad falls in the last couple months. I don't need more safety hazards.
#47 |
I just got my Proxxon micro mill yesterday. did some fiddling with the xy table adjustments and did a test piece. It's a nicely built tool especially for the price.
| Cheap Drill Press | NYCOne | Equipment & Tools | 11 | 15th June 2011 05:19 AM |
| Drill Press Help | Seraph | Equipment & Tools | 46 | 10th December 2010 10:47 PM |
| Recommend decent table top drill press? | stephenmarklay | Equipment & Tools | 7 | 14th January 2010 03:18 AM |
| Might need a drill press | xyrium | Multi-Way | 3 | 22nd June 2005 10:38 AM |
| Anybody with a drill press near Detroit? | EvilYoda | The Lounge | 0 | 26th May 2004 06:43 PM |
| Page generated in 0.09361 seconds (83.72% PHP - 16.28% MySQL) with 11 queries |
