| Equipment & Tools From test equipment to hand tools |
I asked a friend if he could get me a big variac for a nice price. He knew what I needed it for, so I assumed he would find a ~1000VA one.
Since I got it for free, I couldnŽt turn it down. Even tho I wish I had when I went to pick it up. Its really really heavy. The problem is that its 3phase, and I have no idea on how to convert or use it on single phase here at home. If I just connect ground and two of the three hot wires, will it work? I know im only getting 2x0-220 instead of 3x0-220, it dont matter. The goal is to get X-0-X output, e.g 26-0-26 so I can test a chipamp. |
#2 |
Just insulate the inputs to the two phases you don't need.
Connect to the remaining Phase and Neutral, just as you would do for single phase Live and Neutral. Ground, or Earth, or PE are quite separate. None of these are Neutral. But, ask an electrician to check what voltage it is designed for use with. It could be 220Vac or 400Vac for each phase. I think you could wire up one or both of the spare phases to give a second and/or third "in-phase" output/s. Again the electrician should be able to confirm.
regards Andrew T. |
#3 |
If you use it for a chip amp which u can do using your variac, BEWARE that it is not isolated and touching even 26Volts will be lethal.
Gajanan Phadte |
#4 |
I think I can see lots of transformers inside, along with the 3 Variacs.
It will be very easy to measure/check if any outputs are not isolated from the mains.
regards Andrew T. |
#5 |
Live and neutral. Got it.
Come to think of it, I have to connect at least one more fase for X-0-X output. The correct ting would be....? tie the two live wires together? Tying the live and N together sounds very wrong :P There are 3 large transformers (20cm/8" diameter) and one a tad smaller for the DC outputs. The large ones have to be for isolation, right? What else reason is there for putting an extra 45kg of Cu inside? Besides.. voltages below 50v dont scare me very much. To much resistance in our body, so IŽll take my chances with the chip amp. The Perreaux on the other hand... 80-0-80v makes for a nasty rail voltage. |
#6 |
What you've got there actually contains THREE variacs. (I'm well familiar with the configuration, though not that particular piece of equipment).
Take it apart and you will find three cores. May take some dissasembly as they are linked together in a carrier and threaded through with a motorized rotor unit. After taking apart any one core may be connected to your mains as a normal single phase unit. I envy you, thats a nice stack! Doc
Ne timeas a facie mulierum ea ignorare |
#7 | |
#8 |
Too bad you are not closer! I'd make you a trade. Before you ASSUME anything, get a diagram or make one from the hardware.
My guess, like most variacs, it is not isolated. Can't really tell by the pix. Before you hook anything up - make sure that you fully understand the device, have a proper diagram, AND meter it out! Good luck and SAFE - more people die with house current then all others put together. |
#9 | |
But reading back on your goals, the unit you've got is WAY overkill. Even so, if you've got it and it's yours to tear into it will certainly accomplish your goals. To attain a 52V center tap (26..0..26) you may not even need to do any winding, dependingon existing taps on the cores. I myself have made a very nice amplifier power supply by just splitting existing windings with a dremel wafer and then deviding the new issolated secondary into the voltages I needed. Cores like in the unit you've got there typically have multiple taps spaced around them. I'll help to whatever level I'm able to. Doc Doc
Ne timeas a facie mulierum ea ignorare Last edited by thaumaturge; 12th September 2011 at 06:02 PM. |
#10 | ||
If you can't translate english back into something you can understand correctly then you are on the wrong Forum.
regards Andrew T. |
| INA134, balanced an unbalanced, normal phase and inverted phase | CJ900RR | Analog Line Level | 1 | 30th March 2011 03:30 PM |
| Acoustic phase, electric phase,....phase | ermes | Multi-Way | 6 | 27th November 2010 06:17 PM |
| Big Toroids & Big Caps | K-amps | Swap Meet | 10 | 25th June 2009 07:43 PM |
| Big Toroids for amps ..variac rewind | GS300 | Parts | 7 | 23rd August 2008 11:22 AM |
| Having problems with port size... how big is far too big? | fjhuerta | Multi-Way | 10 | 30th August 2005 06:20 PM |
| Page generated in 0.11307 seconds (81.03% PHP - 18.97% MySQL) with 11 queries |
