I am looking for a cost-effective 4-channel digital scope. 4 channel is a must, bandwidth less priority; I can live with 50 or 60MHz.
Other requirement is easy way to transfer graphs in good resolution to a PC for use in documentation.
I found a few that are below or just above $ 1000:
Rigol DS1064B: Rigol DS1064B Digitales Speicher Oszilloskop !!Angebotspreis!!
Instek GDS-2064: Instek Digital Oscilloscopes, DSOs on Sale at Test Equipment Depot
Tek TDS 2004B: https://www.valuetronics.com/New_Tektronix_TDS2004B.aspx
The Tek is discontinued but offered as NOS apparently.
One thing I noted is that although all have 8 bit vertical resolution, the Tek 'appears' to have a more smooth curve rendering, although it is not easy to compare as the pictures have different sizes. But the Tek does have a spec for that.
Questions:
Anybody is using any of these; experiences?
Any other units I missed? Any with more than 8 bit vertical resolution?
Any important issues I should check for?
thanks!
jan didden
Questions:
thanks!
jan didden
You should definitely also consider the new Agilent models. None of the other scopes you mentioned even remotely come close to the performance and display fidelity offered by a basic agilent DSOX2004A. It sells for 1453 euro's here in Belgium. There is also a cheaper 2 channel model. There is an extensive review of this scope at the EEVBLOG site:
http://www.eevblog.com/2011/02/15/e...0-x-series-infiniivision-oscilloscope-review/
EEVblog #143 – Agilent 2000 X Series Infiniivision Oscilloscope Review @ EEVblog – The Electronics Engineering Video Blog
Great link, thanks! Now, I'm going to the US this fall so maybe I need to smuggle one back
jan didden
