Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 28th June 2011, 11:54 AM   #1
askii2 is offline askii2  India
Default Amplifier measurements
Hi All,
I am a newbie in DIY world. Thanks to several interesting threads in this forum, I learned the importance of measuring and calibrating DIY equipment. As the first step of learning, I thought of measuring my present off-the-shelf amplifier. I installed software wave generator and oscilloscope on my laptop. Then connected output to amplifier's input and measured output across output terminals with speaker load connected. I got attached interesting graphs. These graphs have been plotted with the source waveform on Y-axis and amplifier output on X-axis. I did several measurements by varying frequency and using sine and triangular waves. The outputs were more or less same. I am attaching the outputs for triangular waves.
As you can see at lower frequencies I see a clear Elliptical shape. As the frequency is increased the ellipse goes thinner, eventually going flat. I have shown frequency response at 80Hz, 200Hz and 1KHz. 1KHz response isn't a straight line, it's a think set of several lines, which I believe could also be because of instabilities of the laptop output.
Could experts on this form help me understand these graphs? Does an elliptical graph imply a phase shift? If yes, I can conclude that my amplifier causes a phase shift at lower frequencies. The phase shift vanishes above 1KHz.
Thanks.
Old 29th June 2011, 11:57 AM   #2
I am only looking for a general advice. Hasn't anyone done a test of this form?
Thanks.
Old 29th June 2011, 12:32 PM   #3
DF96 is offline DF96  England
You are viewing the amplifier transfer function, although conventionally the input would be X and output Y. An ellipse means phase shift, as you say. This is normal at frequency extremes, both high and low. Phase shift becomes noticeable well before the gain drops off.
This test can show serious distortion, such as clipping or gross crossover distortion, but in a working amplifier it should not show very much which may be why people don't use it very much. Useful for debugging faults, but not for measuring normal function.
Old 29th June 2011, 02:20 PM   #4
Thanks.
It's good that I can use this test to investigate faults when I build circuits. Are there any other similar useful tests?
I am now going to build a notch filter for room acoustic correction. I guess I should be good to go with this test and a multimeter. I'll create a separate thread for it.
Old 29th June 2011, 03:03 PM   #5
xmo is offline xmo  United States
"...Are there any other similar useful tests? ..."
If you are interested in learning about audio tests and procedures, I recommend "Fundamentals of Modern Audio Measurement" and "The Audio Measurement Handbook"
Both are available for download at:
AP High Performance Audio Analyzer & Audio Test Instruments : Downloads
Old 29th June 2011, 04:52 PM   #6
This is a great site. Wealth of knowledge. Thanks
Measurements: When, What, How, Why D OB G Multi-Way 1658 11th January 2011 12:00 AM
are these measurements okay? eitanwaks Multi-Way 3 23rd March 2010 07:32 PM
different measurements resident Tubes / Valves 4 17th April 2005 09:04 PM
amp measurements GAK Tubes / Valves 0 11th February 2004 03:29 PM
Measurements? panos29 Multi-Way 3 20th April 2003 05:07 PM
Page generated in 0.07930 seconds (83.05% PHP - 16.95% MySQL) with 11 queries
