measure speaker T/S parameter, what do I need? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 10th July 2012, 04:32 PM   #21
Originally Posted by Conrad Hoffman View Post
I still use a signal generator and small power amp, a resistor and a meter or scope. I don't like the added mass method and usually knock together a test box or an adapter for some existing box. The numbers I get are generally very close to manufacturers numbers (at least the good ones). The signal generator can be any cheap thing, from antique to modern and the scope can be equally as decrepit. Most meters do OK at low frequencies and it doesn't have to be true RMS. The stuff just has to work and be reasonably accurate. I have a sound card and all the rest but unless I were doing a large number of woofers it's as easy to use the dinosaur methods just like Weems and Speaker Builder described them.
Could you perhaps point me to an on-line resource for how to perform this test? I have the gear, but no idea how to hook it up and interpret the results (for speaker measurement).
Thanks!
Please help in designing speaker box : measure TS params arunraj.in Multi-Way 4 16th December 2010 02:10 AM
Please help in designing speaker box : measure TS params arunraj.in Software Tools 6 11th December 2010 02:55 PM
How to measure an active speaker system? Tyson Multi-Way 2 4th January 2010 04:42 AM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
Speaker impedance measure by a newbie jormartr Multi-Way 1 17th October 2003 02:09 PM
Copyright 1999-2017 diyAudio
