| Equipment & Tools From test equipment to hand tools |
#11 | |
Now, probes are another story. TEK P6139's are not exactly cheap. I think I ended up shelling out $150 for two of them on ePay. Given that they're $400/ea from TEK I figured I'd done a decent deal... ~Tom |
#12 |
For PCB's I'd rather get on of those small dremel drill press jobbies, its basicaly a press you put a dremel tool into, the small size (you can put it in your drawer when not in use), is realy handy. they are quite pricey though at about $30 or so a pop.
BUT, it is far nicer to use on PCB's then a giant drill press. ( I also have a cheap nasty one) the runout on the drillbit is quite horrible, you set it up with the tip centered on the point you want to drill, then when you switch it on the bearings have so much play, the ti pof the drillbit goes in circles around the spot you mark. I usualy use a pin vice to make some leadholes to give it something to catch on to. Last edited by digits; 15th June 2011 at 05:20 AM. Reason: shoe laces were untied. |
| Drill Press Help | Seraph | Equipment & Tools | 46 | 10th December 2010 10:47 PM |
| Recommend decent table top drill press? | stephenmarklay | Equipment & Tools | 7 | 14th January 2010 03:18 AM |
| To drill or not to drill? (a VPI turntable) | m.parigi | Analogue Source | 5 | 6th January 2006 02:32 AM |
| Might need a drill press | xyrium | Multi-Way | 3 | 22nd June 2005 10:38 AM |
| Anybody with a drill press near Detroit? | EvilYoda | The Lounge | 0 | 26th May 2004 06:43 PM |
| Page generated in 0.06946 seconds (70.48% PHP - 29.52% MySQL) with 10 queries |
