| Equipment & Tools From test equipment to hand tools |
#121 |
just another
Hi George, some more measurements as requested, though I'm not sure what to make of them! Certainly not what I was expecting for the 1uF caps.
I did these on the breadboard, so it may be mucking up the measurements. perhaps I really need to solder. the three BC's first. single measured 0.22 or 0.21 ohms two in series measured 2.7 ohms three in series measured 4.4 ohms two in parallel measured 0.02 ohms three in parallel measured 0.02 ohms I then tried 4 X 1uf Axons (polypropylene). single measured 0.16 ohms two in series 2.6 ohms three in series 4.3 ohms four in series 5.8 ohms two in parallel measured 0.01 ohms three in parallel measured 0.03 ohms four in parallel measured 0.06 ohms a single 3.6 uF axon measures 0.01 ohms now the two siemens 100nf single 17 ohms two in series 29 ohms 2 in parallel 8.3 ohms and finally evox rifa 100nF caps single 16 ohms 2 in series 27 ohms 3 in series 42 ohms 4 in series 57 ohms 5 in series 73 ohms 2 in parallel 7.7 ohms 3 in parallel 4.9 ohms 4 in parallel 3.4 ohms 5 in parallel 2.7 ohms (very close to the two 1uf in series results) and just for fun 2 X silmic II 1uF single 2.8 ohms in series 6.2 ohms in parallel 0.73 ohms I'm not going to try and make any sense of all that tonight Tony. |
#122 | |
just another
The only thing I'm not sure about is using two bnc's for the input + and - I'm not that familiar with using opamps, and don't really understand how that is to work. do I only use two inputs when looking at the difference between two signals or is it for balanced input? sorry for my stupid question anyway here is a picture of the first steps Tony. |
#123 |
just another
OK I've slept on it, and figure the way to use the two inputs is to only use the hot of each for connecting to the circuit under test, and only use the sheild on the box end. +ve one to the point of interest, -ve one to the zero volts or earth of the circuit under test. I guess this should remove the possibility of any ground loops between the DUT and the device which is taking the output.
Tony. |
#124 |
just another
I've finished the instrumentation amp tonight
1X 0.0 mV 10 X -0.1 mV 50 X -0.8 mV 100 X -1.6mV 1000 X 16 mv So it looks like the gain settings are pretty much spot on (except for 10X which I was expecting because my resistors didn't work out exactly to 5.49K. It would appear that I have about -16uV offset on the input. Measurements were taken with both inputs floating. here is a picture of the guts Getting too late tonight to try and measure something tonight, but soon Edit: power input is a bit dodgy in that I used a stereo 3.5mm jack, reason being I couldn't find an insulated dc socket (I need to keep the -ve of the battery floating and the virtual zero volts tied to the case). Tony. Last edited by wintermute; 21st November 2011 at 10:12 AM. Reason: comment on dodgy power socket. |
#125 |
Hi Tony
Sorry for my delayed answer. You've done a great construction. A very good alum. housing too. About your question on how to connect the two inputs, you are correct. You can use the "differential" mode , as well as the "single ended" connection (see attached sketch). Have a look at the AD 620 data sheet. If I remember well, the (-) Input is less noisy than the (+) Input. If this is so, the (-) Input should be connected to the weaker signal when you use the "differential" connection When you use the "single ended" connection, the (-) Input should be connected to the "hot" signal and the (+) Input to the GND. Keep on working (and walking Regards George
"Second Law is a bitch." - SY Last edited by gpapag; 29th November 2011 at 08:22 PM. |
#126 |
just another
Thanks George!
| implementing HT bypass in preamp | dvenardos | Solid State | 10 | 31st March 2009 08:08 PM |
| Experience implementing Seas DXT tweeter? | TurboFC3S | Multi-Way | 6 | 19th September 2008 05:06 PM |
| Implementing a Rumble Filter before the Amp? | Bogie | Subwoofers | 12 | 2nd January 2006 10:48 PM |
| Seeking advice on implementing opa627 I/V stage | quantran | Digital Source | 0 | 30th March 2005 07:48 AM |
| implementing side-firing subs into towers | bonsai171 | Multi-Way | 1 | 25th February 2004 03:14 AM |
| Page generated in 0.11320 seconds (77.22% PHP - 22.78% MySQL) with 11 queries |
