Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 16th May 2011, 06:39 AM   #1
whubbard's Avatar
Default Frequency Counters
Hi Guys,
I'm looking at getting a sub $100 frequency meter.
Stumbled across these new ones:
0.01Hz - 2.4GHz Precision Frequency Counter Meter Test | eBay
Multifunction Counter (10Hz¡«2700MHz) TFC2700L
But I'm a little cautious. I'm also quite open to buying used; but I'm worried about it being non-functioning.
Any Recommendations? Do you think either of the first two will work out okay?
-West
Old 18th May 2011, 10:51 AM   #2
whubbard's Avatar
Casual Bump.
Old 18th May 2011, 03:04 PM   #3
What is your goal, audio ?
Counters listed have prescalers, which enable higher frequencies, but at reduced accuracy.
Is your goal accuracy ?
What is the desired frequency coverage ?
paul
Old 18th May 2011, 05:32 PM   #4
macboy is offline macboy  Canada
A prescaler doesn't reduce the accuracy or the precision. It reduces the resolution (from say 1 Hz to 10 Hz). The precision will be the same (# digits) and the accuracy (% error) will still depend primarily on the accuracy of the internal frequency reference. I assume that accuracy is quite limited on these cheap meters; notice the conspicuous lack of an accuracy specification.
Old 25th May 2011, 10:48 PM   #5
tomchr is offline tomchr  United States
tomchr's Avatar
I have an older HP 5334B with the 1.3 GHz input option and temperature controlled reference oscillator. I picked it up on eBay a while back for something like $150. That's incredible bang for the buck.
~Tom
Elapsed Time Counters Irakli Analogue Source 0 30th October 2010 04:09 PM
Resonance Frequency DR ANALOGUE Multi-Way 5 11th January 2006 07:49 AM
Frequency CUT and a HOLE in frequency range... -_nando-_ Everything Else 0 28th December 2005 08:17 PM
Need help w/ tuning frequency jaybird Multi-Way 5 11th October 2004 09:28 AM
What's my x-over frequency? hanskrj Multi-Way 0 5th February 2004 07:20 AM
Page generated in 0.07332 seconds (76.53% PHP - 23.47% MySQL) with 10 queries
