good wire stripper for 26 gauge, which tool? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 13th May 2011, 08:10 PM   #21
Doug Kim's Avatar
Use the soldering gun and be prepared for the bad smell.
Old 13th May 2011, 08:17 PM   #22
digits's Avatar
...and your lungs for even worse contamination.
Old 23rd May 2011, 01:41 PM   #23
qusp is offline qusp  Australia
qusp's Avatar
i'm with Steve, best stripper is a straight edge blade, or a stanley knife. roll over index finger and blade then pull off with fingernail. works on just about anything, not phased by ptfe in the slightest; just need practice to do it cleanly and quickly.
i do it many many times a day
Old 23rd May 2011, 01:59 PM   #24
gychang is offline gychang  United States
I have the technique down now, use the blade and fingers, works well. cheap!
gychang
Good sound from Davis, CA
Old 23rd May 2011, 10:24 PM   #25
Tapco thermal wire stripper. Good even on teflon insulation. E
Old 24th May 2011, 12:36 PM   #26
qusp's Avatar
gychang
glad you like this advanced technique
once you have the technique, there really isnt any need for extra tools, you get a better feel for it too.
with thin solid core wire i will sometimes use a slightly dulled blade to reduce the risk of scoring the wire. its not really that big a problem though considering you usually solder over it and add strain relief (at least i do to every joint pretty much)
Old 7th June 2011, 06:55 AM   #27
If u have do it in hundreds, better buy one of these.
Gajanan
Old 15th June 2011, 04:56 AM   #28
I have a Radioshack wire stripper that does a good enough job and relatively cheap.
RadioShack® Heavy-Duty Automatic Wire Cutter/Stripper - RadioShack.com
Old 15th June 2011, 12:17 PM   #29
This is what I use:
Works great, just need to be careful so the cut is not too deep.
Kolbjørn
Old 21st June 2011, 02:00 AM   #30
evianamp2011's Avatar
For anything smaller than 20gauge you can use a lighter. Just light up the end you wish to strip and hold it to the flame for about 2secs and quickly pinch the end with your thumb and index finger and pull away (trust me it will be a little warm, but you'll get the hang of it). Its so easy that you'll do it everytime you strip them wires.
I learn this from a friend of mine that has no tools. I always use to use my teeth, but now I just go for the lighter. Am pretty sure someone here has done it with a lighter before.
why does teflon insulated wires need a very expensive wire stripper? jarthel Parts 7 30th April 2007 02:53 AM
Looking for cheap 26 gauge solid wire in Toronto area 454Casull Everything Else 3 10th April 2007 07:55 PM
Wire gauge calculator? xyrium Multi-Way 7 12th October 2005 10:36 AM
teflon wire stripper sam9 Parts 15 12th February 2005 09:42 AM
fet wire gauge MikeZ Pass Labs 2 21st April 2004 12:43 PM
Copyright ©1999-2017 diyAudio
