Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 7th May 2011, 10:51 AM   #1
triode_al's Avatar
Default A HV lab supply
The past few days I have been working on a variable high voltage power supply, to make life easier.
I decided to create a CCS that outputs a constant current into a reference resistor, with a buffer (gate follower).
HV laboratory supply.pdf
(I am lost how to get a decent postable picture from my simple drawing tool McCad)
This works like a dream. Very stable. At 2 mV setting of the scope, the output remains completely flat (and our mains is very very fluctuating).
Noise (excluding hum) is almost absent. Less than 0,5 mV.
Hum is visible. Measured on scope less than 3 mV peak-peak 50 Hz, from the pick-up on the long (30 cm) leads to the potmeter I use, and the unshielded 20 turns potentiometer itself.
With a more careful layout and proximity it can be beter even, but hey, 100 dB is not bad. For instance hum already dropped from 10 mV PP to 3 mV PP by earthing the case on the front panel.
The unit ranges from 68 Volt to 315 Volt. This is of course determined by the reference resistor, I choose 100K.
I also added a 6,3 output as that is handy too.
As an extra I think of adding an electronic choke, that also limits the output to about 200 mA.
Albert
See my 2SK175/2SJ55 F5.. CS8412/SAA7220/TDA1541 ; SP-6 Light ; MC30 Super--> a two stage RIAA 2SK240-ECC88/6SL7.
Old 12th May 2011, 11:40 AM   #2
triode_al's Avatar
An update:
The schema, updated:
Here is a picture of the outside
and the somewhat messy insides:
you can see the big rectifier tube 5RU4 and the 6J5 single triode.
I have a big PIO and a starter capacitor (top left) below the provisional voltahe divider for the tube heater. The outside and specs only matter
The CCS is composed of a 2SK30, that manages the triode's current into 100k.
The active choke was taken from A.M.Quinn's website. I have not yet attached this active choke.
albert
Old 14th May 2011, 06:06 PM   #3
escopunk's Avatar
Love that analog amp meter, inspired me to make my own HV power supply, gonna go tube (6L6 or 6550) with solid state rectifiers.
HV lab supply hidnplayr Power Supplies 1 17th February 2010 12:25 PM
Is this a practical HV supply? keantoken Power Supplies 16 26th May 2009 11:48 PM
Switch contacts for HV supply ThSpeakerDude88 Tubes / Valves 4 30th March 2008 03:50 AM
Help with HV DC Power Supply furly Planars & Exotics 3 2nd February 2006 12:04 PM
FS: Fluke HV Lab power supply TerryKing Swap Meet 0 28th April 2004 12:03 PM
Page generated in 0.07519 seconds (73.24% PHP - 26.76% MySQL) with 11 queries
