Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 10th April 2011, 09:25 PM   #1
Default Short question about the "do-it-box"-knobs
Hello there,
would very much appreciate if someone is able to help me get started with my first ever DIY-project - the "Do-it-Box Step Attenuator" set:
Do-it-Box Step Attenuator | Diy HiFi Supply
Everything seem quite straightforward ... but what kind of tool do I need (and what size), to loosen the two knobs on the front?
Thanks!
Denis Olsen
Denmark
Old 10th April 2011, 10:18 PM   #2
sofaspud's Avatar
I would say the knobs use either a small flat screwdriver, or (more likely) a small hex key, perhaps better known as an allen wrench. Couldn't guess a size. Screwdrivers should already be in your toolkit. I have a couple "Swiss army knife" type allen wrench sets that cover >90% of what I run into.
Old 11th April 2011, 11:59 AM   #3
Thank you for your reply! Have already tried all flat screwdrivers in my toolbox, also the very tiniest (only 2 or 3 milimetres), but none gets any kind of grip inside the hole (which is less than 5 milimetres).
Do not have a hex key of that size, but that could do the trick. Have also been told that I might need a very small "torx", which is a tool I have never heard of before.
But as I have seen on the Internet, those tools come i many, many different shapes (at the end you fit into the screw), so it makes it a little bit difficult to know exactly what to buy.
So I will just wait and see if someone comes along with an answer :-) and ask around where I live in the meantime. Thanks.
Old 21st April 2011, 11:47 PM   #4
Default Torx fastner
Torx wrenches are similar to ZXN wrenches used on various European automobiles, typically smaller and with fewer splines..... same general idea however.
Cyclotronguy
Old 22nd April 2011, 07:14 AM   #5
Default Buttons now off! :-)
Fortunately I solved the problem some days ago. Bought a 113 piece bit-set, and the buttons are now off!
What you need is a torx, star-shaped, size T6.
Are now working on finishing the box.
Thank you for your replies! :-)
Mordaunt Short "MS 3-10" - Replacement Bass Transducer tiefbassuebertr Multi-Way 3 20th September 2011 09:43 PM
Goldwood 12" Vented box question ostripper Multi-Way 2 15th January 2011 12:37 AM
XO protyping box: "The Box of Doom" grantnsw Multi-Way 3 7th April 2010 12:11 AM
DIY "speaker box" ("BOOM BOX"). Help needed. MASantos Full Range 6 2nd September 2007 12:00 PM
Wavelength & accoustic "short circuit"? Jennice Multi-Way 3 25th May 2005 10:09 AM
Page generated in 0.08423 seconds (71.79% PHP - 28.21% MySQL) with 10 queries
