| Equipment & Tools From test equipment to hand tools |
#11 | |
frugal-phile(tm)
I do find the quoted statement interesting. 1/2 is to many "sufficient" for audio listening, what is it about sillyscopes that limits it to 1/5? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 |
Greatly oversimplified--the Nyquist frequency (1/2 the sample rate) is the upper limit for resolving sine waves. To accurately display faster rise time signals the sample rate needs to be a minimum of 3-4 times higher than the equivalent frequency of the rise time--5x faster is a rule of thumb, some engineers believe 10x to 20x is the proper ratio.
#13 |
I.e. a 20Mhz scope is only good for measuring 2Mhz square waves.?
#14 |
#15 | |
Take a look at the waveform coming out of most CD players with a test disk having a 10kHz or higher frequency sine wave recorded on it at various amplitudes and you will have your answer.
www.kta-hifi.net |
#16 | |
frugal-phile(tm)
dave
#17 | |
frugal-phile(tm)
dave
#18 |
Good chance with a product such as this is that performance will be sub-par. Sample rate, A/D resolution, input attenuation, etc are all not going to be par with a good oscilloscope. A good reference is that PC based scopes are really not a factor in the test equipment market, and they have a lot more computing horsepower than an ipad.
If you think you need a scope, buy a scope. Anything else is just a toy. paul |
#19 |
Well, I have seen some VERY EXPENSIVE pc based scopes claiming to go out to 200megs... but at a cost where you'd be better off buying TEK.
#20 | |
Most USB "oscilloscopes" have lousy voltage dividers, horribly non-linear frequency response, and are single FPGA based meaning that they are incapable of reading both channels simultaneously--though many claim they do. I keep hoping for something decent and affordable, but mostly they are toys. As a "Lecroy guy" I lean that direction, but the Tek scopes are also great instruments... |
| any recomendations for learning how to use oscilliscope | blakktalon | Equipment & Tools | 7 | 26th October 2010 12:42 AM |
| Buying first Oscilliscope | pjpoes | Parts | 7 | 9th May 2008 12:56 PM |
| Oscilliscope reading 1/2 voltage | mabie | Parts | 7 | 17th February 2008 05:30 PM |
| Sell - BWD525 Oscilliscope (Bne / Qld / Australia) | MadMutt | Swap Meet | 0 | 8th February 2007 10:20 PM |
| Page generated in 0.10023 seconds (79.63% PHP - 20.37% MySQL) with 10 queries |
