Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 8th April 2011, 11:39 PM   #11
firechief's Avatar
Threatening to go off thread. Must resist.
Old 9th April 2011, 12:09 AM   #12
Trondareo, Electrophoresis power supplies do not generate much current so don't know how much use they'd be on the bench except for capacitor reforming. Electrophoresis is done on the wet lab bench by students on upwards and results in few if any deaths.....
My day job is electron microscopy @ 200kV.... the HT power supplies live in refrigerator sized cabinets filled with SF6 gas and though mighty impressive to behold (and very complex as the HT needs to be ppm level stable) can usually only generate about 100 microamps (the end result of all this is an electron beam of some nanoamps...).
Old 9th April 2011, 12:02 PM   #13
trondareo's Avatar
I checked with the seller. This supply delivers up to 800mA, but that would probably be at 250V rather then 2kV. It should be sufficient for anode current for the lower voltage tube designs I like.
It should even manage to power two 6c33c´s at moderate current
(250mA each or so)
I´m doing stuff at http://taooftubes.blogspot.com/
Old 9th April 2011, 12:19 PM   #14
you should get 100-200W out of it, so at the lower voltages you'll be ok. Wonder what the filtration is like? The heatsink is impressive too. Wonder why they are selling it....?
Old 9th April 2011, 05:14 PM   #15
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
The units are usually rated in Watts. Mine automatically limits output current based on Power output.
Old 11th April 2011, 05:59 AM   #16
trondareo's Avatar
Lost it in the last minute od bidding
Hagerman Bugle power-supply or for +/-15dc 100ma generic supply. tweakk Swap Meet 3 23rd February 2011 06:46 PM
U.S.AMPS 100HCA Power Supply Turns on 3 secs then looses Power Kip McGee Car Audio 8 29th September 2010 04:56 AM
DIY Audio Alchemy Power Station 2 Power supply PSU with case roscoeiii Swap Meet 2 29th May 2010 06:51 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.08381 seconds (76.70% PHP - 23.30% MySQL) with 10 queries
