Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 17th March 2011, 04:04 AM   #1
tryalx is offline tryalx  United States
Default Analyzer/tracer for the output signal phase of an amplifier
Hi everybody,
I am looking for an analyzer or curve tracer that can plot the phase/gain (up to MHz range) at the output of an amplifier. I would very much appreciate any recommendations! How would such a device be called, maybe I can google it?
Thank you.
Alexandru
Old 17th March 2011, 02:03 PM   #2
try looking for "Network Analyser"
Something perhaps like an HP3585A as you are asking for 1MHz + bandwidth, these are 20Hz to 40MHz Spectrum and Network Analysers.
Manual from: http://www.home.agilent.com/agilent/...ect=SR.GENERAL
Mik
Last edited by audiomik; 17th March 2011 at 02:23 PM. Reason: add possible instrument type
Old 17th March 2011, 10:51 PM   #3
Hi Mik,
Thank you for your reply. I will look into the network analyzers. I thought there would exist some equipment specialized for audio amplifiers that can plot the gain/phase curve at the output. I would like to see how the phase of the signal looks close to and beyond the unitary gain frequency.
Alexandru
Old 22nd March 2011, 01:14 PM   #4
cliffyk is offline cliffyk  United States
cliffyk's Avatar
Velleman's PCSU1000 and PCGU1000 pair, or their PCSGU250 combo instrument, can produce automated bode plots of the response and i/o phase relationship of nearly any device.
Here's the response (solid lines) and phase (dashed lines, vertical center is 0°) of a small 15Wpc amplifier I designed, at 3 level settings (100%, 75%, 30%) with loudness contour enabled:
The PCSU1000/PCGU1000 combo can plot over several spans from 1kHz to 5MHz, with a number of start frequencies (1Hz to 100kHz depending on span); and has a special 10Hz to 30kHz audio range. The PCSGU250 has similar bode plotting capacity with a 1MHz upper limit IIRC.
The system can automatically scale the oscilloscope's gain to obtain a maximum dynamic range is 75dB, not spectacular but not bad. This is limited by the 'scope's vertical gain range (5mV to 2V/div) and sensitivity, and the DUT's signal capabilities.
Old 23rd March 2011, 11:00 PM   #5
Thank you! The PCSU1000/PCGU1000 combo is a nice tool. I wish the frequency generator would go up to the 30Mhz range. I am mainly interested at looking at the phase of the output signal from 1.5Mhz up when the gain becomes unitary.
Would the software that comes with the PCSU1000 oscilloscope give you numeric values of the difference in phase between the two inputs of the oscilloscope? In that case I could use a "manual" frequency generator that I have and combine it with the PCSU1000.
Thank you!
Alexandru
Old 24th March 2011, 06:55 PM   #6
cliffyk's Avatar
The PCSU1000 can do that (as can many DSOs).
Here's a PCSU1000 screenshot of a 3kHz signal on CH1, and the same signal passed through a simple RC filter to create a phase shift on CH2:
The phase display is on the left, showing CH1 32.8° "ahead" of CH2, and CH2 being 32.8° "behind" CH1. The peak-peak and RMS levels of each channel are also shown; these could be used to determine when you have achieved unity gain.
Note that the RC filter has reduced the magnitude of the filtered signal (CH2), this would of course not be the case with your unity gain scenario.
Here are the same signals displayed on a Lecroy WaveJet 322, with the period of CH1 and the "skew" of the two signals being measured:
The WaveJet displays the skew of 35.3μs, and period of 333.3μs. To convert skew and period to phase in degrees = 35.3/333.3*360 = 38.13°.
In the last here's what these signals look like on a Lecroy 9354L:
With phase displayed directly in degrees.
These were created at 3kHz as that was convenient to the RC filter I had at hand--there would be no difference in methodology at 3MHz...
Old 24th March 2011, 09:03 PM   #7
Thank you for taking the time to explain me in such a detail, and for the pictures that very nicely demonstrate the approach!
I looked on my Rigol DS1102 oscilloscope and it doesn't provide the automatic measure of the skew parameter. Yet, I found the option to enable two pairs of cross hairs which I can position on each of the channels. This way I can derive the skew value and compute the phase with the simple formula you mentioned.
I am happy with this solution for moment, although it would be nice to have a plot as you posted previously.
Thank you,
Alexandru
Old 24th March 2011, 11:01 PM   #8
cliffyk's Avatar
Yup, using cursors to measure the skew will work nicely...
Also I just looked at the Rigol DS1102 specs, it looks as though you have CH1->CH2 Delay measurements for both the rising and falling edges--those are the same as "skew":
Old 25th March 2011, 06:40 AM   #9
You are a genius, the Delay1 -> 2 gives me exactly what I need! I guess I haven't fully explored what my Rigol DS1102 can do.
I have measured a delay of 80ns at 2Mhz when the gain becomes unitary, which gave me 57.6 degrees ... that is pretty good.
Thank you so much for your support!
Alexandru
Cheap Phase/Gain analyzer dtproff Power Supplies 0 23rd October 2010 07:31 AM
Onkyo amplifier A-RV401 - output signal to speakers cuts intermittently gerolo Chip Amps 4 12th October 2010 08:03 PM
HP 35660A Signal Analyzer power supply needed alaskanaudio Parts 2 8th February 2003 12:34 PM
Page generated in 0.10548 seconds (79.52% PHP - 20.48% MySQL) with 10 queries
