Good cheap Soldering station, any votes?
Hello and Thank You,
The old dog Weller is not dead but the insulation on the cord to the iron is old and repaired in several places.
I now have a shiny new Hako 936 B from Fry’s for $75 US sitting next to it on the bench.
Here is the question. Assuming that calibration is correct on the heat setting of the 936 what temperature do I set the dial for 63% SN 37% Pb solder, 390 degrees F, 30 higher than the melting point of the solder?
Kind of a survey question!
DT
All just for fun!
