| Equipment & Tools From test equipment to hand tools |
..and need more eyeballs to go over it.
I'm about to embark on a PCB layout, but would like a second opinion on the circuit to see if I need more 'feature creep'. I have all this Tektronix 5000 series test gear and they all support GPIB control to automate their behavior. The missing link is a switchbox to change routing programmatic-ally to allow tests that need external routing changes. Some of those tests would be:
My Tek MI5010 is loaded with three 50M30 DIO cards and can drive up to 48 relays directly, so I don't have an issue if I need to add more switching. Looks like I'm up to *just* 27 now A routing matrix fordoing an entire console at once is something I can do later/separate. I'm just concerned about the single ins/outs right now. So the question is... What did I forget? Also, I tried looking at using a CPLD to data compress the states down to 16-bit (thus just one 50M30), and even wrote the VHDL source for it. The problem, or I guess my fear, is that I had to go with a Xilinx XC9572-7-PC84. That's 84 pins!! Though I need 40 I/O lines, I barely touch its capabilities... That, and a $230 programmer, too, but it is cheap @ $7.35 in singles Digi-Key - 122-1444-ND (Manufacturer - XC9572-15PCG84C)
Think out of the box
#2 |
eyeball comes.
do you mean the switchbox could be controlled by GPIB |
#3 |
yup. The Tektronix MI5010 with three 50M30 cards can directly power 48 relays and is controllable over GPIB. So a test suite summary example for measuring input CMRR would be something like this:
Code:
> switch bypass < switch OK > osc do sine;1000Hz;rms(1.228V) < osc OK > dist do measure db < dist measure ready > getdata dist -> $a > switch input bal-CMRR > dist do measure db < dist measure ready > getdata dist -> $b Input impedance would be this off hand: Code:
> switch bypass;inputZ-V2^- relay0 enabled on the input brd< switch OK > osc do sine;1000Hz;rms(100mV) < osc OK > dist do measure volt < dist measure ready > getdata dist -> $v2 > switch inputZ-V1^- relay0 and relay1 enabled on the input brd and relay5 enabled on the output brd monitoring across R1.> dist do measure volt < dist measure ready > getdata dist -> $v1 The question I have is... Have I missed any common tests in the switching unit that require routing changes? I think I have everything, but knowing myself.. as soon as I build it I'll realize something I forgot. I'd go over this with the other folks at the job, but none are qualified to help. That's why I'm here. My test gear isn't that helpful to me if I don't ever follow through and automate it the way it was meant to be.. and frustration is the true mother of all invention because all the qualifying tests I have to do take forever and this isn't how things are supposed to be.
#4 |
more complete schematics of my switcher project idea. Not sure yet of the proper grounding scheme, but will follow AES54-2-2008 as best I can.. one input test does need a terminated pin1 at the DUT.
Usually my indicator of when a design is done, is when there is nothing more to take away. In this case, I guess I do need to churn out a unit and stop over-thinking it to discover missing features by using it <sigh> I'll keep it modular (each schem will be PCB) so it'll be easy to mod. The whole logic board will be the part that'll take the CPLD if I ever go that way. I'm up to 37 relays now. 4 more and I'll have to get a larger CPLD than that 84 pin one. bwaa haa haa.
| Testing gear, where to start? | prickears | Multi-Way | 14 | 16th September 2009 01:16 PM |
| Audio and related gear | zargon1 | Vendor's Bazaar | 0 | 4th October 2008 02:47 PM |
| Acoustic testing gear recommendation | audio3000 | Full Range | 6 | 16th August 2005 12:35 PM |
| Sansui audio gear? | Lisandro_P | Everything Else | 4 | 17th December 2004 10:28 PM |
| You know you love audio/gear when... | eRiCdWoNg | Everything Else | 1 | 27th March 2004 06:05 PM |
