Re-greening the Heathkit IG-18 - Page 9 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 22nd May 2012, 06:24 PM   #81
DDB is offline DDB  United States
Dick has posted a major update to his mod #3 of the Heath IG-18 using a HP339A style design. IG-18 #3
Old 15th June 2012, 08:16 AM   #82
richiem is offline richiem  United States
richiem's Avatar
I've completed two variants of putting the HP 339A oscillator circuit into an IG-18 -- one is the 339A circuit using the 100:1 tuning cap ratio:
IG-18 #3, the IG-339A and B
The second is the 339A circuit using the Heath stock tuning caps:
IG-18 #4, the IG-339B
The pages include high-res distortion spectra, showing 1kHz results in the 1ppm area. Neither of these are quite as good as Bob Cordell's SV circuit in the IG-18, but they're still very good.
Old 21st June 2012, 11:02 PM   #83
klewis is offline klewis  United States
klewis's Avatar
Dick,
It all looks very good! A question for you about your boards, the ferills that you fit the JFET and some resistors into, where did you get them? Part number? I presume they are for easy swapping of parts.
Ken
Old 21st June 2012, 11:58 PM   #84
davada is offline davada  Canada
Originally Posted by klewis View Post
Dick,
Ken
Hi Klewis,
I'm not sure where Dick got his but I have seen at Digikey.
David.
David.
Old 22nd June 2012, 03:48 AM   #85
richiem's Avatar
Hi Ken -- those are Augat socket terminals for wire wrap. Got them a million years ago and have no idea now what the part number is. All I can remember is that they came from Digi-Key. They have collet-type sockets very similar to the pins in good DIP sockets.
Old 22nd June 2012, 04:41 AM   #86
Hi Dick,
That's a very good point about the dip sockets. I have disassembled a few collet type 8PDIP sockets and used the pins for SOIC breakout boards. A bit of solid wire inserted into the socket pin and then into the breakout hole holds the pin while being soldered.
I find this produces a much better end result than using male header strip.
David.
David.
Old 22nd June 2012, 04:45 AM   #87
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
IG-339? I like it! Somehow I have to scrape up money for parts to get my SV oscillator board up and running.
Old 22nd June 2012, 04:28 PM   #88
klewis's Avatar
Found them at mouser, had to resort to the paper catalog. R32/C Vector | Mouser
note that the price is for 100 pieces.
Old 22nd June 2012, 07:28 PM   #89
These are available at digi. $0.65 for one.
http://www.mill-max.com/images/products/pdf/166N.pdf
David.
David.
Old 16th September 2013, 09:49 PM   #90
mrsavage's Avatar
Default new PCB's board designs
Other PCB designs exist, but what about a new one that includes the latest
op-amps and voltage regulators. I would be interested in a group buy for these
new designs.Click the image to open in full size.
Heath IG-18 IG-5218 jackinnj Equipment & Tools 55 16th September 2013 11:30 PM
Heath IG-18 converted to state-variable design richiem Equipment & Tools 3 15th June 2012 08:09 AM
Heatkit IG 18 schematics please! AJT Solid State 5 18th September 2010 09:18 PM
Nice Heathkit IG-5218 Low Distortion Audio Sine/Square Generator dozer Swap Meet 2 12th January 2009 02:50 AM
Morrey IG-18 mod audiohead Solid State 6 22nd March 2008 06:55 PM
Copyright 1999-2017 diyAudio
