Re-greening the Heathkit IG-18 - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 20th October 2010, 07:51 PM   #11
richiem is offline richiem  United States
richiem's Avatar
@jackinnj -- very interesting spectra -- thanks for sharing. The Audio Precision has very low even order products, while the Krohn-Hite has low odd order. I suspect that the relatively high even order products in the K-H result from residual channel modulation in the AGC FET. Is the K-H a phase-shift/state-variable design, as I suspect?
Does the AP use software generation of the sine wave with a DAC output? If so, then maybe the odd-order stuff is from the output amp, whatever it is.
I haven't put hands on either of these units nor have I seen schematics.... I'm guessing that the roughly 6VRMS output is close to the max for both units, is this the case?
Old 20th October 2010, 09:08 PM   #12
jackinnj's Avatar
The AP will do 26.66V, the KH 7 V RMS
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 20th October 2010, 09:17 PM   #13
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
Here's a partial of the IG-1272's schematic, showing the important bits:
Q101: MPF105
Q102= SM62186
Q103, Q105= S2090
Q104= S2091
Last edited by Damon Hill; 20th October 2010 at 09:25 PM. Reason: Add transistor #s
Old 20th October 2010, 11:59 PM   #14
I see one possible modification to the IG-1272: the output level is also the power switch, meaning the AC line is very close to the signal line with possible noise and 60 Hz pickup.
Old 21st October 2010, 04:16 AM   #15
richiem's Avatar
@jackinnj -- 26.66V?? How, and why?
Old 21st October 2010, 04:59 AM   #16
richiem's Avatar
@ Damon Hill -- without seeing the bridge configuration -- I'm guessing here on much of the detail -- I think that, given the equal capacitor values in the multiplier switches, this is a Wien Bridge, in which case the resistors of the bridge arms in the frequency switches have equal values as well. The JFET is the input transistor and is in cascode with Q105 for higher gain and high input Z. The Wien bridge config needs a very high input Z at the amp input due to the large resistors needed for low frequencies.
The three lamps are the only AGC. What I did in the IG-18 may equally well benefit this unit -- raise the emitter resistance of Q102 to 1k and the collector load of Q105 to 10k or 20k, then play with the feedback control. The bootstrapping of Q104 with the 100u cap from the output gives higher output voltage swing, but I think I would give up some output level and use a constant current source, either FET or transistor, as the collector load for Q102, replacing R177 and 178. The 22 ohm emitter resistors for the output devices are a little large for a two-diode bias scheme -- there's a risk of crossover distortion -- might be good to reduce those to 15 ohms each. I'm really confused about why they returned the lamp string via two capacitors to the two supplies, rather than via capacitors to ground -- but returning to the supplies ensures that the caps always have the correct polarity bias; but I can see problems from noise from the supplies getting back into the AGC loop. Better, I think to make a non-polar cap out of 470uF/35V units back to back, and run that to ground.
Finally, ? is there a buffer amp, like an emitter follower, for the meter? If not, this is a must-have for better distortion performance. See my greening page on the IG-18:
IG-18 #1
My 2 cents.
BTW, given the split supplies, this unit is a natural for using a FET-input op-amp like the OPA604 as the gain stage which would make some of the suggestions above unnecessary. Of course, you'll have to lower the supply rails to +/-18V or +/-15V-- I think this would be easy with a change in the resistor values that go from the regulator control pins to ground.
I imagine this unit can do much better than the original design....
Old 21st October 2010, 05:14 AM   #17
No meter buffer, a little detail they left out. I'll build a couple and try them out.
I have a batch of Panasonic 220 uF NP caps originally intended for amplifier feedback, but I could try them in this application.
I'll do a better scan later on, but it'll have to be multipart to get the entire thing.
Always liked the look and build of the later Heathkit gear, back in their days of emulating the HP "look". I've got both the IM and THD meters, AC meter and the FET meter, which apparently needs some work. Still using my ancient IO-105 scope built back in the early 70's.
Old 21st October 2010, 08:22 AM   #18
richiem's Avatar
@ Damon Hill -- I'd like to see how the THD meter is similar to and different from the HP 33/334, especially since I'm well into greening a 334 -- just finished wiring up a replacement A3 rejection amp board. A few things left to do, then it's time to see if it works. Do you have the manual for that as well? Let see, was it the 5238? Can't quite rmember.
RE the Panasonic NP caps -- excellent, if they have the voltage rating -- should be 25V or more, 50V would be great.
Old 21st October 2010, 01:01 PM   #19
jackinnj's Avatar
Here's the amplifier section of the later version of the Boonton 1120 -- works quite well up to ~140kHz -- you would have to beef up the power supply to use it:
Board Layout:
Old 21st October 2010, 05:41 PM   #20
richiem's Avatar
Thanks, jackinnj -- full-bridge amp, plenty of voltage swing, tons of feedback. Nice.
Heath IG-18 IG-5218 jackinnj Equipment & Tools 55 16th September 2013 11:30 PM
Heath IG-18 converted to state-variable design richiem Equipment & Tools 3 15th June 2012 08:09 AM
Heatkit IG 18 schematics please! AJT Solid State 5 18th September 2010 09:18 PM
Nice Heathkit IG-5218 Low Distortion Audio Sine/Square Generator dozer Swap Meet 2 12th January 2009 02:50 AM
Morrey IG-18 mod audiohead Solid State 6 22nd March 2008 06:55 PM
Copyright 1999-2017 diyAudio
