usb audio interface - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 9th October 2010, 04:44 PM   #11
frugal-phile(tm)
planet10's Avatar
Originally Posted by luvdunhill View Post
Dave, can you post basline RMAA measurements of this unit, with no DUT connected?
From my tests, it doesn't perform as well as say a E-MU 0404 USB.
If i knew what you were asking i might be able to respond (but the answer is probably no)
Does the EMU fo 24/192?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th October 2010, 05:10 PM   #12
luvdunhill's Avatar
I can post measurements later. Yes it does and can even do 32 bit measurements. I think you'll find the noise floor is about 10 dB lower as well, but I'd have to verify that with my tests.
For Sale: Yet-Another-FirstWatt-PSU | "CSX1/2" "Buffered F6" FE
Old 9th October 2010, 05:36 PM   #13
frugal-phile(tm)
planet10's Avatar
Yes it does (24/192) and can even do 32 bit measurements.
Not in practise (at least for me): "Macintosh analog operation up to 96kHz and digital operation up to 48kHz only at this time."
It does 32 bit internal processing with 24 bit I/O. I expect that that is pretty common as it is the most sensible way to use the 32bit wide processors.
dave
Old 9th October 2010, 06:33 PM   #14
luvdunhill's Avatar
I have run tests with 32-bit I/O I can post. Yeah, if the drivers aren't up to snuff on the Mac, I'd look elsewhere.
Old 10th October 2010, 02:58 AM   #15
luvdunhill's Avatar
So, the Edirol uses CS5340 ADC and AK4385 DAC.
The E-MU 0404 uses AK5385A ADC and AK4396 DAC
The specs just looking at the datasheet shows what's theoretically possible.
E-MU 0404 in 32/96
E-MU 0404 in 24/96
Edirol FA66 (I cannot find my graphs for this one, but these are within +-0.2dB of what I remember, despite the sampling rate difference:
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
Interface : USB or NOT renaudagnes Digital Source 40 9th December 2009 06:13 PM
EGO Sys Gigaport HD- 8 channel USB Audio Interface? Gutbucket PC Based 1 28th August 2009 01:09 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
Copyright 1999-2017 diyAudio
