Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 12th August 2010, 06:30 PM   #1
Default Which solder for audio?
Im no expert, im looking in some websites and i see 40/60, 62/66....what
does it mean and what is the difference?
I need good quality (but not those crazy expensive like Mundorf).
Its for soldering resistors and caps to an audio amp pcb.
Old 12th August 2010, 06:48 PM   #2
SY's Avatar
Regular tin-lead with a small (2-4%) silver content if you're dealing with silver wire or terminals, 63/37 for anything else. Anything more exotic than that is hype.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th August 2010, 06:55 PM   #3
zigzagflux's Avatar
Amen
Old 12th August 2010, 07:22 PM   #4
I have gold plated terminals, no silver wires (from what i know).
What is 63/37? don't i need audio grade for the amp? if so, than what brand?
Old 12th August 2010, 08:04 PM   #5
Trebla is offline Trebla  United Kingdom
It's 63% tin and 37% lead, but it's probably not worth worrying about.
Better to acheive a good join with any old solder, than a poor one with designer stuff.
I'm afraid i don't know what audio grade solder is.
To be fair though, some solders are nicer to use than others. So you are bound to get some recommendations.
Old 12th August 2010, 08:32 PM   #6
SY's Avatar
Regular solder with a high price tag and a story.
I'd recommend Kester 44, Ersin Multicore, or (heaven help me) Radio Shack silver-bearing. Really, any "name" brand non-audiophile solder will work fine, some slightly better than others in some applications.
Old 12th August 2010, 08:36 PM   #7
LeonvB is offline LeonvB  Netherlands
60/40 is the composition of the solder. Normally the default meaning is the Tin/Lead content in a percentage, or with the chemical symbols and the percentage if otherwise. So added together it should be 100, meaning 62/66 does not exist.
Nowadays I'm using Sn95Ag4Cu1 from Stannol. It's leadfree and silver based, so you can use it on almost anything including plating containing silver and it's almost the same as 'exotic' solders while costing much, much less (Mundorf is 95.5%Sn/0.7%Cu/3.8%AgAu (AgAu=99%Silver1%Gold)). Very easy to use, good flow. Very strong joins.
I agree that for anything not requiring silver content you could use much cheaper solders like Sn99Cu1. I would avoid lead based solders, but for DIY it's an obvious choice as you probably have some lying around and even if you don't it's still a little cheaper (but not that much).
Old 12th August 2010, 09:09 PM   #8
Mine says 40/60, does that mean 60% lead? and why is lead bad?
Do i need silver in the solder?
Old 12th August 2010, 09:13 PM   #9
hispls is offline hispls  United States
I'd love to see any double-blind tests where anyone can "hear" the difference between lead/tin and silver/gold solder. LMFAO, I'm pretty certain that you would need incredibly precise equipment to see any difference whatsoever (and I mean reading thousandths of an ohm).
Electrons probably don't care too much how much you paid for your solder when they're flowing through it.
The only real downside with lead is it's toxicity AFAIK
Old 12th August 2010, 09:15 PM   #10
So...just look for any lead free solder?
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 03:13 PM
Best solder to use rtarbell Parts 4 20th November 2005 01:05 AM
can I solder on this? Duck-Twacy Multi-Way 9 24th February 2004 12:46 PM
how do you solder? theChris Equipment & Tools 15 2nd January 2003 10:55 AM
Solder again Christer Parts 13 6th December 2002 12:48 PM
Page generated in 0.10000 seconds (79.78% PHP - 20.22% MySQL) with 10 queries
