Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 4th August 2010, 12:41 AM   #21
indianajo's Avatar
Default Quality crimp connectors
The Thomas & Betts & Ideal first line crimp terminals are seamed. They are not made in the orient, and are quite expensive. The last box I got was $11 for a box of 100, and that was 6 years ago. The metal is thicker in the crimp area than Panduit, 3M, everything else. If tyco a new name for AMP, I have used AMP but only with an industrial air powered bench crimp machine. They only sold terminals in reels for machine installation when I was specifying them. You can get a "dimple' crimp with the Ideal tool by using the "non-insulated" slot after using the "insulated" slot to start. I usually do. I have found pvc insulation to be entirely adequate for hooking up automotive & lawnmower engines. Reliability is important to me because I drive my 51 year old car 42 miles round trip to the country 100 days a year, and there is only one pay phone in route. No, I don't use a cell phone. The engine and ignition harness, the windshield wipers, and now the turn signals, are all self manufactured harness using crimp terminals. Pro grade crimp terminals. I eliminated the weird Murray rider mower 11 terminal "starter" switch last year when the connector on the back rusted through, and did that entire harness in crimp terminals. The only problem has been thick woody saplings grabbing the charger wire and pulling it off at the terminal- force a bit higher than any terminal is meant to withstand.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 11th August 2010, 10:27 AM   #22
dangus is offline dangus  Canada
The "ins" position is for crimping the sleeve over the wire insulation, if the terminal is of the appropriate type. (That is, with a thinner sleeve of metal under the plastic. I haven't seen many terminals that were suitable, other than a vintage box of name-brand ring terminals.)
I think the seamed connectors are OK; I just make sure the dimple is on the non-seamed side.
insulated turret terminals arend-jan Tubes / Valves 32 15th November 2009 01:17 PM
Anybody near Toronto have experience with Half Price Tools purplepeople The Lounge 2 21st May 2008 03:00 PM
Any have experience with Proxxon tools? RDL2004 Parts 5 10th December 2004 06:27 AM
Which Paladin die to crimp these ring terminals? andy_c Parts 3 27th August 2004 02:14 PM
Page generated in 0.05244 seconds (82.51% PHP - 17.49% MySQL) with 10 queries
