| Equipment & Tools From test equipment to hand tools |
Hi
Any sugestions of a DIY L-meter using a 0-500Mhz frequency counter? IŽll need it to work at least in 1-100 Henry range (or more), and with DC bias IŽll found some diy projects out there, but most in to low Inductance range and no DC-bias Regards Pix Sweden
Pix |
#2 |
Z = 2 pi f L
#3 |
Yes sure, But I was thinking more of a resonant circuit, where I could calibrate the circuit for the freq. counter to display the inductance without calculations and with accuracy
/Pix
Pix |
#4 |
Unless the coil has a very high Q and low parasitic capacitance you won't get a very sharp peak -- but it can be done that way. Meters like the HP5328 have signal shaping circuitry to help ferret out the peak. Ham radio "Grid Dip Meters" were variable frequency oscillators, you attached a capacitor and swept the frequency until you got a null.
A bridge circuit is pretty easy to build -- |
#5 |
I don't see how that works; it looks as though all it's doing is measuring the dc resistance of the inductor.
To measure inductance, which is defined in terms of rate of change of current, you need a signal that changes with time. Of course it's easiest to get an inductance bridge, or even one of those old G-R or EICO or Heath impedance bridges. (I have an extra G-R bridge.) Measuring with a counter will require a variable signal frequency. Getting direct readout is a little more trouble. |
#6 |
It is a bridge, an ESI 250 Bridge --
Getting back -- you can make a Colpitts oscillator with just one transistor -- in this case the time interval of 10mS is proportionate to the value of the inductor: |
#7 |
Is that bridge circuit doing it ballistically? Close the switch and look for the direction of deflection on the detector?
It ought to be possible to just build an oscillator with the DUT and a few switchable reference capacitors, and read the frequency with the counter. IMO, a proper bridge circuit and AC source is better because you can get both value and Q. Not hard to build but if you just buy a used GR1650 everything's already done for you, probably with parts better than you can easily buy today. Not sure about the max range- why do you need such a high value? Oddly, the GR716C capacitance bridge lists measuring extremely high inductance values under "other uses" in the manual. Like MH (not mH), though I've never run across one (MH, not 716C).
I used to be an audiophool like you but then I took an arrow to the knee. |
#8 |
My G-R 1650A is a fine instrument, accurate and has a wide range. I don't use it because I have a newer model.
But any inductance measurement must take into account the frequency of operation. If it's intended for high frequency use, an audio frequency measurement is of limited value, and vice versa. In addition, it it's got a ferrous core, the amplitude of the signal and any dc through it are important factors. |
#9 | |
The ESI250 has a 1kHz generator, I couldn't find a 1650 inexpensively when I was looking. I've owned some other ESI stuff and it's always been very good. |
#10 |
I've almost finished a rewrite of my 716C web page- just need to take some photos. The GR section is one of the last corners of my site that still needs to be redone. I spent last weekend making new polypropylene insulators for my 716 and got the leakage from 150 megohms to about 30 gigohms. What a pita to change out. Hopefully this coming long weekend I'll be able to calibrate it and do more capacitor testing. So far the skeptic in me thinks no human should be able to tell the difference between most decent caps in a blind test. Still, there are easily measurable differences and the most perfect caps are probably certain ceramics, followed by polypropylene. I'd need more samples to say if Teflon is routinely better or not. At the moment I'd have to say it's not money well spent, unless one is building precision integrators. BTW, Henry Hall, who designed the Digibridge, told me they used Teflon caps in some of those so the first measurement would agree with subsequent measurements.
Inductors are also quite interesting since they're a far less perfect component than caps. Lots of construction compromises one can make with geometry and wire choice. I tend not to use them for audio, only for switching supplies ;-)
| how to make this esr meter work with 250uA Panel meter | dytln_02 | Everything Else | 2 | 27th January 2007 10:13 PM |
| inductance meter from a cheap meter? | jarthel | Parts | 3 | 22nd September 2006 05:37 AM |
| Making a milliAmp meter, become a Volt meter | redrabbit | Power Supplies | 11 | 26th May 2006 07:51 PM |
| t-amp vu meter and volt meter question.... | rectaacies | Class D | 7 | 3rd February 2006 11:22 AM |
| Yokogawa DL7100 4-Ch 500MHz Scope | zinsula | Parts | 3 | 17th May 2005 06:52 AM |
| Page generated in 0.10839 seconds (75.68% PHP - 24.32% MySQL) with 11 queries |
