| Equipment & Tools From test equipment to hand tools |
#11 |
Check out the swivel bases. Painters use these all the time; easy to use, screw use scrap wood, say 12" x 12" on both sides, bolt one side down to table or saw horses and spin the "table", not the router.
This is much safer also. AND you can use it for painting later on……… Can send a pic for clearer image. McMaster-Carr Last edited by ODougbo; 30th December 2011 at 08:27 PM. Reason: "" |
#12 |
too much play. Just put a snug nail between two sheets of mdf.
#13 |
Oh and spin the top sheet, yeah I guess that would work. The thin, 12" turntable work nice ~ no play at all, it has ball bearings.
Running in router circles works, but the cord gets tangled up – it’s all good/easy with a little practice. |
#14 |
How to measure?
Example: say you want a 6” hole, measure 3” from the outside of the bit to the center of the pivot (which could be a simple nail or screw). It is important to measure dead center of the hole, even if that seems insignificant. Holes too big or too small are not much fun when building speakers. |
#15 |
had to come up with a circle router, and fast
and I decided it had to be adjustable turned out to be exstremely simple I bet anyone can find the materials within 5 minutes and besides, when changing router bits, adjustment changes |
#16 |
Hows this for simple
#17 |
#18 | |
Sorry, no router for you. Last edited by revboden; 25th January 2012 at 11:49 PM. Reason: missing word |
#19 |
well, I dont have a workshop, and rarely repeats the same routing
but if I were, I would definateky use a fixed jig like your much better for repeating the same routing job its a more 'professional' way but my routing is always different from yesterday |
#20 |
That's a good set up, my Makita came with something like that (with the bars) so all I needed to do was drill a hole in a alum support (square block at the end).
Its a little easier and safer if you "swing" the baffle board, vs. swinging the router. You can get fancy and buy/find a flat ball bearing (round table) or simply put two work-boards together with a nail in the center. Perfect circles are easy to cut, easier than square; Imo. Don't cut too deep in one pass......Wear eye protection! Router Bits can snap, and/or worse They spin around 25,000Rpm, depending on the router. |
| [USA] Freebie: slightly broken Jasper No 200 circle jig | eRiCdWoNg | Multi-Way | 2 | 2nd September 2005 09:18 PM |
| WTB : Jasper Circle Jig | Cacophonix | Swap Meet | 2 | 23rd March 2005 04:35 AM |
| Looking for Japser Circle Jig | chris ma | Swap Meet | 14 | 6th June 2004 01:02 AM |
| Home made circle cutting jig | nuppe | Everything Else | 3 | 5th June 2004 12:39 PM |
| FS: Plunge router and Jasper circle jig | bsteeves | Swap Meet | 7 | 18th June 2003 05:29 PM |
| Page generated in 0.10555 seconds (78.20% PHP - 21.80% MySQL) with 11 queries |
