| Equipment & Tools From test equipment to hand tools |
My interest is in building, designing/prototyping interconnect cables.
Of most importance, I need to build a fair number of interconnects and need to develop a test to ensure basic quality of termination, beyond signal continuity as tested with a voltmeter. Things like cold solder joints which cause noise but still allow signal to pass. Other flaws in connectors, wire, etc. Also interested in measuring effects of shielding on EMI and RFI noise attenuation, linearity of cable design. I read the thread on purchasing used oscilloscopes. Buying an Oscilloscope Based on the threads recommendations I have decided on picking up a reconditioned/calibrated/90 day warranty Tektronix 265B from a reputable source that I have been dealing with for the past 5 years. Question 1: For basic production problems. As opposed to listening to every pair, is there a good testing technique that can be employed? Possibly using a function generator, or other device. This same company has a number of options for gently used/calibrated function generators. At the high end, they highly recommend the HP33120A, ~ $1000: The Agilent 33120A Function / Arbitrary Waveform Generator uses direct digital-synthesis techniques to create a stable, accurate output signal for clean, low-distortion sine waves. It also gives you fast rise and fall-time square wave, and linear ramp waveforms down to 100µHz • 15 MHz sine and square wave outputs • Waveforms, Standard: Sine, triangle, square, triangle, ramp, noise, sin(x)/x, exponential rise and fall, cardiac, dc volts • Waveforms, Arbitrary: length 8-16000 points, 12 bits (incl. sign) amplitude resolution with 40 MSa/s Sample Rate They also have many units under $500. Question 2: If I am going to do testing as well as cable research/prototyping, will the HP33120A be a good investment? Any good suggestions on function generators to complement the Tektronix 465B? I am looking for something that generates the signal with low distortion. What about something like a less expensive Wavetek unit, e.g. the Wavetek 134 which can do "sine, square, triangular, and sawtooth waveforms with selectable and variable outputs over a dynamic frequency range of 0.2 Hz to 2 MHz. Can be operated as a triggered or gated CW generator and as a continuous or triggered sweep generator. Sweep time of 10 µsec to 100 sec, up to 1000:1 with calibrated control." Advice on a function/sweep generator... Thanks in advance for any suggestions. |
#2 |
In all my years of working in this field I have never had use for a function generator. Sine wave, yes. No other waveforms have been needed. A good quality audio generator is necessary if you are measuring distortion, but of course in that case you need a distortion measuring device. If you want to rely on your eyes on the screen for distortion, almost any generator will do, from the Heath and EICO and Knight on up. Or you can build one easily.
Oscilloscopes need to have whatever bandwidth you intend to use. If you want to track signals in a 10.7 MHz strip, of course you need bandwidth greater than that. If not, then something with response beyond, say, 100 kHz is adequate. If you intend to work with Class D and up amplifiers, you will definitely need more sophisticated equipment. High sensitivity on a 'scope is handy, say 5 mV/div. You need probes too. No need for delaying sweep, storage, other bells and whistles. (Except as mentioned above for switching type amplifiers and power supplies.) Measuring power output of amplifiers requires 8 Ohm power resistors. You should have a variable autotransformer to control the power input to the amplifiers, and it's doubly useful for applying low voltages after a repair job. And an audio voltmeter to get more accurate results than the 'scope can provide. |
#3 |
In looking for defects I would be looking at visual differences between a reference signal from a known good cable and that from the defective cable. In case of resolution would 2mV/div be better than 5mV/div? the Tektronix 465B is 5mV/div. The Tektronix 2465B is 2mV/div and appears to be more $.
#4 |
audio express had an article a while back 3-4 months, concerning conectors. The author suplied a circuit for evaluating the various types of conectors. The author is here somewhere
ah I found it, its post 7644 in thred I don't believe cables make a difference, any input? |
#5 |
With most audio work, cables matter very little. If you have a very long run, are in a corrosive environment, or are working with second rate equipment, well maybe.
The best tests for cables are to measure capacitance, resistance, and insulation integrity. You don't need an oscilloscope for that. If you have an open cable and want to repair it, measure the capacitance at each end and it will tell you where the break is. |
#6 |
The HP3312A is the older version of the 33120A. The older function generator is a good piece of gear and can be had for relatively little cash. The 33120A is awesome! Very low THD on the sine wave and fast square wave.
I think for cables, though, the best test method is a TDR (Time Domain Reflectometry) measurement. All that's required is a fast oscilloscope and a step generator with an insanely fast rise time. ~Tom |
#7 |
Could you provide a link to this article? I looked on the audioXpress web site and wasn't sure where to look. Or is on another site?
#8 | |
Time-domain reflectometer - Wikipedia, the free encyclopedia TDR Tutorial - Intro to Time Domain Reflectometry TDR Circuit Also can the HP3312A and HP33120A serve as the step generator, with insanely fast rise time? I am a diyAudio newbie so please excuse the trivial questions. |
#9 | |
"Distortion Meter" by Ed Simon (who is a member of our forum).
Kevin |
#10 |
If I were going to design and test cables, a function generator and scope would be about last on my list of things to buy. I'd want a milliohm meter and something to measure impedance, a vector voltmeter at the low end, or a network analyzer at the high end. Or a decent impedance analyzer. I think TDR can work to a meter or less. Even a decent CGRL (LCR) bridge would be useful.
Conrad
I used to be an audiophool like you but then I took an arrow to the knee. |
| function generator - need advice | rize | Equipment & Tools | 29 | 30th April 2010 10:28 PM |
| Function Generators on steroids for sale | NotInTheMafia | Swap Meet | 1 | 23rd March 2005 04:54 PM |
| Advice on a function/sweep generator... | darkmoebius | Parts | 5 | 25th February 2004 06:57 AM |
| Sweep Generators | yldouright | Swap Meet | 1 | 29th June 2003 01:53 PM |
| Advice Needed - Looking for a function generator | UncleJessie | Everything Else | 2 | 26th March 2003 12:36 PM |
| Page generated in 0.12569 seconds (80.98% PHP - 19.02% MySQL) with 10 queries |
