Go Back   Home > Forums > Design & Build > Equipment & Tools
Equipment & Tools From test equipment to hand tools
Old 10th February 2010, 06:17 AM   #1
Default USB FFT (Cheap ?)
Do you know any USB oscilloscope that, with a software, can be used also as a FFT ?
Thanks,
Davide
Old 12th February 2010, 09:09 PM   #2
cliffyk is offline cliffyk  United States
cliffyk's Avatar
Almost any of them, one of the least expensive for audio frequency work would be the Syscomp Circuit Gear CGR-101 ($189 from Saelig, a bit less perhaps elsewhere).
It also uses 10-bit ADCs, for a theoretical 60 dB dynamic range which would get you close to being able to observe 0.1% THD using the FFT analysis. The typical 8-bit scopes with FFT are pretty much worthless for any distortion analysis as their 48 dB range limits distortion analysis to just a bit better than 0.5%.
Old 13th February 2010, 12:29 AM   #3
star882 is offline star882  United States
star882's Avatar
If audio is all you need, you can just use a sound card and Baudline.
baudline signal analyzer - FFT spectrogram
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 21st February 2010, 02:48 AM   #4
womai is offline womai  United States
I have designed an USB/PC based oscilloscope that can also do real-time FFT. Available as a self-assembly kit or fully built up and tested:
DPScope - A Low-Cost PC-Based Oscilloscope
Wolfgang
Old 21st February 2010, 07:02 AM   #5
Frex is offline Frex  France
It seem to be an interesting product, and good value for money.
However, a very important point for an audio instrument is the dynamic range.
I don't have find which resolution allow this instrument. Probably 8 or 10 bits...
Unfortunately, FFT will be not very usable for fine audio investigations.
it's still a very good job !
Frex
Old 21st February 2010, 07:17 AM   #6
Resolution is 8 bits as you suspected (except for datalogger mode, where it is 10 bits).
The hardware itself would support 10 bits, although the maximum sample rate would be a bit lower (takes more time to store 2 bytes per sample than 1), but that wouldn't be a big issue - around 200 to 500 kSamples/sec would still be more than enough for audio. 10 bit sampling would need some changes to microcontroller firmware and PC software, but nothing really dramatic.
Old 24th February 2010, 08:39 AM   #7
ghg is offline ghg  Austria
ghg's Avatar
Hi
10bit and 500ksps would be fine,
just make sure the input conditioning gives the 10bit -> 60dB dynamic range, too.
Please, add a FFT screen pic to your web page.
BR
Gary
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 26th February 2010, 05:59 AM   #8
PedroDaGr8's Avatar
Wolfgang
Well I'll be, I just read your instructable today. I am going to be purchasing one of your kits once I have a job again (anyone want a chemist in San Diego? ).
Nice job on it.
Old 2nd March 2010, 04:51 AM   #9
what about this ?
EasySync USA
Davide
Old 2nd March 2010, 03:55 PM   #10
cliffyk's Avatar
Originally Posted by Nikon1975 View Post
what about this ?
EasySync USA
Davide
I had forgotten about the StingRay. It has been available for several years now, and is 12-bit.
The software is decent, better than many others, and most important to me it let's you change the ghastly black background to something readable on an LCD screen. I am often bemused by how PC instrument manufacturers are so hell-bent on simulating "real" instruments that they simulate the bad parts too--like black background display areas, unnecessary range selection buttons, and the like.
Cheap Asynchronous USB jkeny Digital Line Level 5 26th September 2009 11:24 AM
Anyone tried those cheap usb sound cards? Westerp Digital Source 1 5th May 2009 09:47 PM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
cheap usb oscilloscope for measuring amplifiers umut1001 Class D 27 5th September 2007 01:33 PM
Page generated in 0.09910 seconds (77.25% PHP - 22.75% MySQL) with 10 queries
