| Equipment & Tools From test equipment to hand tools |
#11 |
I recently acquired an dso nano at :
http://www.seeedstudio.com/depot/dso-nano-preorder-p-611.html?cPath=11 It is usable for audio measurements..but has limited bandwith..is single channel.. But only $89.00 ![]() I upgraded it with Pauls firmware from: http://translate.google.com/translate?hl=en&ie=UTF-8&sl=zh-CN&tl=en&u=http://bbs.e-design.com.cn/bbs/dispbbs.asp%3Fboardid%3D5%26Id%3D8&prev=_t&rurl=tr anslate.google.com&twu=1 This firmware allows calibration of all vertical multiplication factors..i compared it with a calibrated oscilloscope at work.. |
#13 |
Single Tektronix 2225 is for me of my oscilloscopes. Better than this is not needed at all.
Is for me a Velleman pc500 oscilloscopes. But analogue Tek the real one for me. You need to buy an used Tek analogue scope and thats it is. Gyuri
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat |
#14 |
Picked up a Tek 2235 off e-bay. Works pretty well, but I still preferred the old 465's.
Cheap scopes, and I have had Heath, Hitachi, and Ramsey, are not worth the frustration. That is why a cheapskate like me bought a used Tek. Tek, HP, maybe Phillips. I have an old IG-18 and with an upgraded power supply. The big low distortion mod was never stable, so it has the original board back in it. Also a couple of Heath VTVM's. The Heath AC VTVM is actually just as accurate as my HP. Don't use the Heath generator as I bought a HP 209. PM me if anyone is interested in it cheap. I like the sweep rather than step for speaker testing. For low distortion, I use PC based generators in my spectrum analyzers. |
#15 |
Zelscope seems to be the best PC based scope without a custom module. Still frustrating, which is why I bought the Tek.
#16 | |
Not ready to buy a proper analoge scope so this would be a perfect starter.. |
#17 |
Soldering Gun Fanatic
Svein, you have GOT to tell me where to get a 'scope in Norway for under a million, trillion Kroner
Now, all concerns aside, how good is that DSO Nano, with it's limited bandwidth and screen resolution? |
#18 |
A student scope is good enough - look for a college equipment auction or recycle center. ~$50-80 for a 2 channel 20-40MHz scope, probably leader or some off brand, but probably quite serviceable. Don't buy if you can't turn it on and at least see a trace....
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#19 |
I can't say DITTO strongly enough. A 502A or 56x series will do you forever.. and they'll run that long, too. Personally, I think the 502A is the best audio scope with its differential inputs, high gain and amazingly sharp screen. Use the high contrast green filter, too.
Think out of the box
| New Oscilloscope? | joetama | Equipment & Tools | 12 | 6th October 2009 01:32 PM |
| Need help with oscilloscope | error0 | Equipment & Tools | 2 | 6th April 2008 01:22 AM |
| Economical large format bass-horn | broughd | Subwoofers | 11 | 8th January 2008 04:18 PM |
| My DIY economical subwoofer | igod | Subwoofers | 4 | 10th February 2004 08:31 PM |
| How to use an oscilloscope | SimontY | Equipment & Tools | 15 | 16th September 2003 10:46 AM |
| Page generated in 0.10054 seconds (78.08% PHP - 21.92% MySQL) with 10 queries |
